Xfce themes ported to Haiku
Hi all,
Xfce Themes for Haiku… (all 93 of them) :blush:
Only one special caveat I implemented
  • Sliding Title bar is disabled as not to break theming.
Some preview screenshots
Simply install and use xfce themes. No reboot or special hooks required: Download 64/32bit
This is awesome! It’s even got my beloved Crux!
Just thought I’d would mention, for the past hour and probably next hour, I have been running Claude to scan each theme for subtle errors and glitches… The AI has found 50 such problems and fixes, but going with thorough deep scan that will make the next version really nice hopefully.
that looks really cool
Hi all,
xfwm_decorators 1.0.6 is out.
This version fixes a lot of decorator mishaps, subtle misalignments, broken themes, and also adds hover effects for buttons.
If the theme you like misbehaves with the hover effects, you can toggle hover effects off by running:
xfwm-hover off turns hover effects off.
xfwm-hover on turns hover effects on.
xfwm-hover status to see the current status.
If you notice a theme that is really broken or otherwise, please report it. Appreciate ya!
Updates to xfce themes
  • Fixed rounded corners glitch showing small pixels instead of rounded corners
  • Fixed several themes showing an extended bottom bar - thanks @mazbrili for pointing this out.
  • Fixed several themes from using a default black grab bar regardless of Appearance color choices.
  • Fixed several themes to use more blending and better highlight coloring. e.g., “theme xfce-alternate”
Your work is really cool. Haiku by default lacks of alternative decorators. But forgive me I repeat myself… again… can you move the “close gadget” to its right place? It’s HAIKU :slight_smile:
The gadgets were redone in the b5 and b6 family of themes, see b5+ and b6+ and b6+r for those that had the update/fix.
Do you just porting already drawn decorators or are you able do draw your own according to your imagination and needs?
they are ported from xfce, although i think b5+ b6+ and b6+r are custom
