Could Haiku OS x86 get gcc4.7, for C11 support?
There is GCC 5.4, type setarch x86
If I’m already using Haiky x86 nightly, do I still need to run setarch x86
in order to update gcc? Could you elaborate what’s going on?
You do not “update”. The image comes with both versions installed, gcc 2.95.3 and gcc 5.4. You use setarch to change the path and put one in the other in the path as “gcc”.
