Sure!
Guys, when I save a file and reopen it after closing the application, the border of the cells disappears⊠and I donât see any option to draw the borders⊠![]()
Later o can upload a screen about that issue
Before saving
After save, close sum-it, open again and load
EDIT: I can show grid in the Settings MenĂș⊠itâs not the common but well, i can do it ![]()
Also i have the documentation (From be_basics) itâs possible publish that? Is just an HTML file and i can change the images (Copyrighted i supose)âŠ
Hi, a few bugs ![]()
- The name, Sum-IT is a commercial product and the git puts OpenSum-IT, what is the real name of this software release? (https://sum-it.sourceforge.net/ as hystorical reference)
- When clicking/save the default folder it is/system/apps/and should be/boot/home/not to start in a system reading only.
- The formulas related to the content of the cells do not work in 64 bits.
- 1+2 = 3 (thats ok!)
- A1+A2 = Error!
- IF(A3=0,âZEROâ,âOTHER NUMBERâ) = Error!
- When loading a file after saving it and closing the program, the cells or the grid are not shown. (You can activate after load the file, (Ctrl+left mouse))
- When maximizing after entering data, the entire spreadsheet is not shown, only the initial visible part.
- There is no documentation. (I can write one based in the official one and push in⊠a git? what git?
I donât know if report in the git or in other place:
About the formulas:The hpkg doesnât have BSL and/or REZ (Needed to compile, but donât know if needed on run) i donât know if itâs related⊠but is info ![]()
EDIT: Some Screenshots:
32 bits workflow
64 bits error
Regards!
