Will this dual keyboard (Roman / Devanagari)work on haiku os?
Dual keyboard, USB type are marketed commericially here in India…will this work on Haiku?
From what I see, that “dual” part is just the labelling of the key caps. So IF I am correct, it would work just as any other keyboard and you’d get whatever is defined in the keymap preferences for each key. That is, not the devanagari, unless you’ve finished and chosen that keymap.
