I tried to change settings on this router via web interface…http://tplinkwifi.net or typing http://192.168.0.1
Webpositive will take me to login page…after entering the password, it simply stays idle…
on tplink website, he says it should be possible to log on from windows/linux/mac-os
Does it mean not possible from Haiku-os?
WebPositive have troubles with some websites. Your best bet to use a different OS to configure your router.
You could try Otter Browser first!?
Maybe it will work!
If not use your Mobile or another OS to configure Your Router first. Web+ will work better with next Beta 3 release, I hope!?
Is it provided in the r1beta2 image? Since I do not have internet connection at the moment, cannot download other for installation
No it isn’t, but you may be able to install it vi sneakernet, that is to put it on a thumbdrive
https://depot.haiku-os.org/#!/pkg/otter_browser/haikuports/1/0/02/-/1/x86_64?bcguid=bc154-OMWA
It’s probably easier to use another OS to configure it once though, since the deot server doesnt include the deps automatically for downlods of packages
Is it still a WIP?
It works and I include it in my build, but it has some style problems and I am not sure that it follow existing device manager design. Nobody commented on patch.
I think there is no real solution for all this… I will have to buy new hardware or wait for my rtl8192EE to be recognized
My sincere thanks to all those who responded and tried to help me get internet connection
I want to mark this post as ‘SOLVED’, but I am unable to edit the title…somebody pl. guide how to do it
When will this be available via the nightlies?..fed up seeing ‘unknown’…
