Hi Samurai
my name is ilario and i live in italy i installed Haiku yesterday on my pc Fujitsu Amilo 8010 (intel centrino), i’m having some problems with the connection to the wifi network ie:
after installing “install-wifi-firmwares.sh” the hardware of the card is recognized but it does not find the wifi network. then i enter it manually network name and wpa2 password, but it still does not work saying that the network name or password it is not correct.
do i need to make other settings?
Also Haiku can’t find Bluetooth and SD drivers…
last thing: how to change the Read Write permissions of the “driver” folder
Thanks for the support
ilario67
