As my modern laptop’s wireless networking card is not supported neither by FreeBSD nor Haiku, I will buy a WiFi USB dongle so that I can connect to the internet from Haiku. I might as well use it with my old PC, which is incapable of wireless networking. Since I am going to primarily use it with my laptop, I want it to be somewhat compact. If it is equipped with an antenna, I would like it mounted on the back and not on the side. Can you please recommend me some WiFi USB dongles compatible with Haiku and FreeBSD?
Do you think that TP-LINK TL-WN722N v3 will work? It works well with FreeBSD. I need something with better range because Internet connections in my town are terribly slow. Our maximum download speed is 10 MB/s!
I’ve pretty much given up with the tiny USB wifi sticks, poor range, & seldom supported - nowadays I mainly use TP-Link TL-WN822N units, they aren’t as bad as you might at first think, you can hang then around your neck if you have to be ‘on the move’.
If you happen to have an old wireless router lying around you can repurpose it as a bridge between WLAN and ethernet. This would require a working ethernet port on your computer.
Sadly, my laptop doesn’t have an ethernet port and it only has 2 USB ports. I miss the days when laptops had 5 USB ports, 2 HDMI ports and and ethernet ports.
Got me this one (also one of those TP Link dongles), works fine, although on a fresh R1B4 the network speed was really bad, after updating a thumbdrive to the latest updates for R1B4 and installing that over the (freshly) installed Haiku it really blasts!
