I am new to it . please help me where can I test my code…
Hi, sainiaditya1! Welcome to Haiku!
Is your code a contribution to the Haiku system, or an application on Haiku?
A bit more info what you are coding would help to give you a good answer.
Great! What do you have coded?
And are you a beginner or advanced coder?
This answer seems too obvious, I may have misunderstood the question:
Haiku applications run under Haiku…
Maybe this Haiku C++ tutorials help.
Beginners:
Advanced:
Hello and welcome to Haiku communtiy,
for testing compiled software use the non-packaged folders in home or system. You can use my HPKGCreator too. This tool allow to make a hpkg file of your program to install to the system.
If you are working on open source programs, you can use haikuports too.
regards lelldorin
