The links in my saved message lists from a couple years ago no longer works. Does someone want a new host site for it?
Marisa
Marisa
It is on the BeSly repo, according to this.
For the record… depot.haiku-os.org allows searching for more than just HaikuPorts repo, one just needs to select the desired repos after clicking that tiny icon next to “HaikuPorts” (on the same line where you enter the text you want to search).
Thanks! Somehow I missed that post.
