I’ve installed mesa_x86_devel
, but pkg-config isn’t showing any opengl
library (and I have made sure I’m using the x86 pkg-config!).
It can see other OpenGLES, but unfortunately I need real OpenGL…
mesa_x86_devel
is the package for the secondary architecture (i.e. GCC 11, instead of GCC 2.95, which will have its libraries in mesa_devel
instead.) You will need to be within setarch x86
, and make sure you also have pkgconfig_x86
installed also.
I’ve found the problem — mesa_x86_devel
just doesn’t contain a gl.pc
file. It’s got osmesa.pc
, glesv2.pc
, glesv1_cm.pc
and egl.pc
, but no gl.pc
. The mesa_devel
package does contain a gl.pc
Where should I file a bug?
