Hey all, I have a minor issue with WebPositive. I don’t recall when this first started, but webpositive is frozen in the top left posistion of the screen. The tab is hidden, but the command bar shows. So I don’t have a handle in which to move the frame.
I assume there is some fancy way to move it? Any ideas would be great, thanks.
You can actually drag windows by their border, not just by the tab. So if you click in the narrow border to the right of the scrollbar, you can move it that way. But probably WebPositive should be patched to fix this (it just needs a MoveOnScreen call after restoring the old window position.)
Well, that was embarassing. You got it in one. Seems to be fixed now.
Thanks!
An easier way is to hold ctrl alt and you can move it from wherever.
Userguide: Haiku's GUI
Ctlr+alt+arrow keys wouöd be nice to have.
If the mous is not working!
