Hello there !
Well, not so much progress on WebKit this week. I spent most of the time working on CMake code to get it to generate hpkg files. I got something that works well enough to link Web+ to it, so I can test things with the actual browser instead of HaikuLauncher. Today I added the cookie jar persistence, so Web+ remembers all the cookies when you exit and relaunch it. I also started working on HTTP authentication. These are the two features I couldn’t test with HaikuLauncher, as it lacks some code for them (saving cookies on exit, and showing the HTTP authentication password prompt window).
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/pulkomandy/2013-10-25_webkit_weekly_report_5/
