VNC, FTP, and Virtualbox
The good, the bad, and the ugly… I got VNC installed. No clear instructions for setup, but I found instruction on Be.wildman-productions.org It seems to work quite well, so that is good.
The one problem I had when trying to get the files into my VirtualBox machine is that FTP seems to not exist in terminal. SFTP does, but I don’t want that. Haiku has an FTP server built in to the network preference pane, but no easy way to set up like in BeOS. Is there a way to get FTP working in terminal?
And the OK but messy part, and the reason for all this, is that I’m trying to set up Haiku in a virtual machine on a OS X server. Following the instructions, everything went OK. The mouse input has such a delay that makes it just ability unusable. The delay doesn’t exist with the VNC connection.
I use Haiku on a VMFusionware virtual machine on Mac OSX and I’m able to copy files to/from the host using an SCP GUI (Fugu) - there are instructions somewhere here on the forum about setting up the ssh-host on the Haiku machine
Fugu: Fugu SSH download | SourceForge.net
I’d rather use FTP since it’s simple and works on any OS without much hassle, including BeOS. I do appreciate having options though so thank you.
The speed issue with the mouse lagging terribly is pretty much resolved. I wasn’t even thinking that I am so used to remoting with VNC into the OS X side. It was Haiku on VirtualBox through VNC from one mac to another that was causing a delay. That was happening with a different virtual machine but I resolved it somehow to where I could VNC into host and use guest machine fine. When I used host machine locally, the mouse movements were fine in Haiku.
I was able to use VNC in Haiku via the terminal.
  1. Go to /boot/system/bin/vncserver (enter)
  2. Go to /boot/system/bin/vncpasswd (enter) and set the password.
  3. Open Remmina on the client and change the connection to VNC.
  4. Enter the IP address and password.
However VNC is extremely slow in Haiku
