So one of the options I found in Parallels Desktop was the ability to add a serial port that could output to a file. So I did that, then I found that the file was filled with output as the OS booted. I assume this is a log of sorts, so that may provide some idea about what is going wrong during the boot sequence?
get_boot_partitions(): boot volume message:
KMessage: buffer: 0xffffffff8200ccb0 (size/capacity: 315/315), flags: 0xa
field: "booted from image" (BOOL): true
field: "partition offset" (LLNG): 0 (0x0)
field: "boot method" (LONG): 1 (0x1)
field: "boot drive number" (LLNG): 0 (0x0)
field: "disk identifier" (RAWT): data at 0xffffffff8200cd9c, 79 bytes
get_boot_partitions(): boot method type: 1
partitioning system: partitioning_systems/intel/extended/v1
KDiskDeviceManager::_AddDiskSystem(partitioning_systems/intel/extended/v1)
intel: ep_std_ops(0x1)
intel: ep_std_ops(0x2)
KDiskDeviceManager::_AddDiskSystem() done: No error
partitioning system: partitioning_systems/session/v1
KDiskDeviceManager::_AddDiskSystem(partitioning_systems/session/v1)
partitioning system: partitioning_systems/intel/map/v1
KDiskDeviceManager::_AddDiskSystem(partitioning_systems/intel/map/v1)
intel: pm_std_ops(0x1)
intel: pm_std_ops(0x2)
file system: file_systems/devfs/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/devfs/v1)
file system: file_systems/attribute_overlay/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/attribute_overlay/v1)
file system: file_systems/rootfs/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/rootfs/v1)
file system: file_systems/packagefs/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/packagefs/v1)
file system: file_systems/iso9660/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/iso9660/v1)
file system: file_systems/write_overlay/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/write_overlay/v1)
file system: file_systems/bfs/v1
KDiskDeviceManager::_AddDiskSystem(file_systems/bfs/v1)
number of disk systems: 10
KDiskDeviceManager::_Scan(/dev/disk)
PCI-ATA: Controller in legacy mode: cmd 0x1f0, ctrl 0x3f6, irq 14
PCI-ATA: init channel...
PCI-ATA: channel index 0
PCI-ATA: bus master base 0xe000
PCI-ATA: init channel done
ata 0: _DevicePresent: device 0, presence 1
ata 0: _DevicePresent: device 1, presence 1
ata 0: deviceMask 3
ata 0: probing device 0
ata 0: signature of device 0: 0x0000
ata 0-0: model number: Haiku-0 SSD
ata 0-0: serial number: H4D77C4YSFSMB4Q9YR03
ata 0-0: firmware rev.: F.2VJJ9M
ata 0-0 error: more than one DMA mode selected, not using DMA
ata 0: identified ATA device 0
ata 0: probing device 1
ata 0: signature of device 1: 0xeb14
atapi 0-1: model number: Virtual DVD-ROM [1] ÿ
atapi 0-1: serial number: - 31415B265
atapi 0-1: firmware rev.: FWR1ÿ
atapi 0-1 error: more than one DMA mode selected, not using DMA
ata 0: identified ATAPI device 1
publish device: node 0xffffffff82baa468, path disk/ata/0/master/raw, module drivers/disk/scsi/scsi_disk/device_v1
ata 0-0 error: invalid target lun 1 for ATA device
ata 0-0 error: invalid target lun 2 for ATA device
ata 0-0 error: invalid target lun 3 for ATA device
ata 0-0 error: invalid target lun 4 for ATA device
ata 0-0 error: invalid target lun 5 for ATA device
ata 0-0 error: invalid target lun 6 for ATA device
ata 0-0 error: invalid target lun 7 for ATA device
publish device: node 0xffffffff82baa008, path disk/atapi/0/slave/raw, module drivers/disk/scsi/scsi_cd/device_v1
atapi 0-1 error: invalid target lun 1
atapi 0-1 error: invalid target lun 2
atapi 0-1 error: invalid target lun 3
atapi 0-1 error: invalid target lun 4
atapi 0-1 error: invalid target lun 5
atapi 0-1 error: invalid target lun 6
atapi 0-1 error: invalid target lun 7
ata 0 error: invalid target device
Last message repeated 12 times.
PCI-ATA: Controller in legacy mode: cmd 0x170, ctrl 0x376, irq 15
PCI-ATA: channel index 1
PCI-ATA: bus master base 0xe008
ata 1: _DevicePresent: device 0, presence 0
ata 1: _DevicePresent: device 1, presence 0
ata 1: deviceMask 0
ata 1: ignoring device 0
ata 1: ignoring device 1
ata 1 error: target device not present
ata 1 error: invalid target device
KDiskDeviceManager::_Scan(/dev/disk/ata)
KDiskDeviceManager::_Scan(/dev/disk/ata/0)
KDiskDeviceManager::_Scan(/dev/disk/ata/0/master)
KDiskDeviceManager::_Scan(/dev/disk/ata/0/master/raw)
found device: /dev/disk/ata/0/master/raw
DMAResource@0xffffffff82baa3c8: low/high 0/100000000, max segment count 512, align 2, boundary 65536, max transfer 33553920, max segment size 33554432
slab memory manager: created area 0xffffffff90001000 (518)
slab memory manager: created area 0xffffffff90801000 (551)
KDiskDeviceManager::_Scan(/dev/disk/atapi)
KDiskDeviceManager::_Scan(/dev/disk/atapi/0)
KDiskDeviceManager::_Scan(/dev/disk/atapi/0/slave)
KDiskDeviceManager::_Scan(/dev/disk/atapi/0/slave/raw)
found device: /dev/disk/atapi/0/slave/raw
DMAResource@0xffffffff82bbcf10: low/high 0/100000000, max segment count 512, align 2, boundary 65536, max transfer 524288, max segment size 134217728
slab memory manager: created area 0xffffffff91001000 (554)
KDiskDeviceManager::_ScanPartition(/dev/disk/ata/0/master/raw)
trying: partitioning_systems/intel/extended/v1
returned: -1
trying: partitioning_systems/session/v1
returned: -1
trying: partitioning_systems/intel/map/v1
intel: pm_identify_partition(0, 0: 0, 137438953472, 512)
returned: -1
trying: file_systems/devfs/v1
returned: -1
trying: file_systems/attribute_overlay/v1
returned: -1
trying: file_systems/rootfs/v1
returned: -1
trying: file_systems/packagefs/v1
returned: -1
trying: file_systems/iso9660/v1
identify(0, 0xffffffff80efefa8)
returned: -1
trying: file_systems/write_overlay/v1
returned: -1
trying: file_systems/bfs/v1
returned: -1
KDiskDeviceManager::_ScanPartition(/dev/disk/atapi/0/slave/raw)
returned: -1
raw_command:
returned: -1
intel: pm_identify_partition(0, 1: 0, 638386176, 2048)
ata 0 error: device still expects data transfer
Does this provide enough information to get a better idea of why the normal booting from “CD” doesn’t work in Parallels?
NOTE: I couldn’t post the whole log due to length restrictions here… so perhaps important parts are missing?
