I recently got a new USB 3 hub with an Ethernet port, but although USB ports including the PD port work fine, networking does not, can’t connect.
Adapter is a Dockteck USB C Dock Ethernet:
USB C Hub HDMI 4K 60Hz, 6 in 1 Dockteck USB C Dock Ethernet, MacBook Pro Adapter iPad mit LAN RJ45, 2 USB-C Port Daten 100W PD, 2 USB 3.0, HDMI
(Ethernet chipset unknown yet but will find out)
A similar adapter worked fine before, but I had to return it as it was not mine.
I need this to get network access in Haiku, since I sadly still can’t connect to my WiFi even with the excellent progress on the Intel wlan driver recently, which allows me to browse networks and get to the authentication prompt, but doesn’t connect, although the password is correct.
@waddlesplash regarding the wifi issue above, should I reopen and add this to #14298 ([8086:3165] Intel iwm driver not loading for idualwifi7260) – Haiku ?
Works fine under Manjaro Linux.
