https://dev.haiku-os.org/ticket/18203
64 bit hrev56578+65 R1Beta4
Intel Core i5-8400
Intel processor in energy saving mode.
Network disabled.
~> iperf3 -c 127.0.0.1 -R -t 50
Intel Core i5-8400
Network disabled.
Off topic silly question:
how do you get/set processor mode ?
This should be described at ProcessController but it isn’t
CC @humdinger
Already taken care of. Although, if you want to know if there’s a powersaving mode and don’t happen to look into the ProcessController page of the user guide, you won’t read it. OTOH, if you look at the ProcessController menu “Power saving” is a dead give-away and doesn’t really need much explanation… ![]()
I updated the screenshot (still showed both the removed default, “Low latency”, and “Power saving” menu items), and added the text:
ProcessController allows putting the system into a Power saving mode, at the cost of a slightly increased latency.
