Hi, I am trying to use the ping for pinging an ipv6 link local address.
I have setup an internal network in Oracle virtual box . In this network , I have a linux VM and haiku VM .
The linux VM network details are in the following picture
I know nothing about it but, addresses consist of 6 groups of 4 digits separated by semicolon, right?
Then, is it normal that your netmask has 8 groups?
I am unable to ping in bridged network also.
When I am trying to ping , tcpdump is not showing any outgoing packets also.
Command used
tcpdump -npi /dev/net/pcnet/0 icmp6
Getting the following output
sendmsg: Network Host Unreachable .
@cmeerw@waddlesplash Any idea on this ping for ipv6 ?
Also, given there have been some changes to ping code recently, which haiku version should I be using if I want to access the old ping ?
Haven’t used VBox for a long time now, could check VMWare Player when I got that booted (doesn’t happen much anymore). Tried in Qemu, that didn’t work there, but also uses different IP so was to be expected.
@korli for the ipv6 ping to work, the ipv6 modules must be loaded properly …Is that corrrect ? If so, how can I verify if the modules have been loaded properly ? What logs should I check ?
you need to add a local ipv6 address: ifconfig /dev/net/virtio/0 inet6 2a02:1748:dd5c:c9e0:7604:663d:2df:cefa
add a default route for ipv6 route add /dev/net/virtio/0 inet6 default
