Uefi boot hangup
Good to hear.
Regarding your ‘unable to boot from disk’. I have experienced this. In my case, I did not read the UEFI Booting instructions properly and I missed this the below step (which is in the installer and not in the Drive setup). If it is missed, it wont boot on the drive Haiku was installed on.
Install the boot software into the EFIBOOT partition.
  1. Close Drive Setup, and hover over the Tools > Install EFI loader option.
  2. Select the partition you created in step 3.
The “below” in this message sounds AI-generated. As a reminder, it’s not permitted to post AI-generated messages on the forums.
Fine. I used a snippet from a large text, won’t do it again.
You could try to disable ACPI as well!
