Here goes the sys info of this laptop.
Haiku just does not boot with hrev55347 and log on screen says “incompatible hardware”
Here goes the system info:
[code]
Machine: Type: Laptop System: TUXEDO product: TUXEDO Aura 15 Gen1 v: N/A
serial: Chassis: type: 10 serial:
Mobo: NB01 model: NL5xRU serial: UEFI: INSYDE v: 1.07.08TTR3
date: 03/18/2021
Battery: ID-1: BAT0 charge: 42.7 Wh condition: 42.7/48.3 Wh (88%) volts: 16.9/15.2
model: Notebook BAT type: Li-ion serial: status: Full
CPU: Topology: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 31939
Speed: 1430 MHz min/max: 1400/2000 MHz boost: disabled Core speeds (MHz):
1: 1430 2: 1335 3: 1613 4: 1449 5: 1397 6: 1394 7: 1400 8: 1394
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics: Device-1: AMD Renoir vendor: CLEVO/KAPOK driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636
Display: x11 server: X.Org 1.20.10 driver: amdgpu compositor: kwin_x11
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.0-5mx-amd64 LLVM 11.0.1)
v: 4.6 Mesa 20.3.5 direct render: Yes
Audio: Device-1: AMD vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: CLEVO/KAPOK driver: N/A bus ID: 05:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.0-5mx-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
chip ID: 10ec:8168
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus ID: 03:00.0 chip ID: 8086:2723
IF: wlan0 state: up mac:
Drives: Local Storage: total: 585.01 GiB used: 90.86 GiB (15.5%)
ID-1: /dev/mmcblk0 model: ED4QT size: 119.25 GiB block size: physical: 512 B
logical: 512 B serial: scheme: GPT
ID-2: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
serial: rev: 1B2QGXA7 scheme: GPT
Partition: ID-1: / raw size: 137.24 GiB size: 137.24 GiB (100.00%)
used: 16.00 GiB (11.7%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 320.27 GiB size: 314.24 GiB (98.12%)
used: 74.86 GiB (23.8%) fs: ext4 dev: /dev/nvme0n1p4
ID-3: swap-1 size: 8.00 GiB used: 0 KiB (0.0%) fs: swap
swappiness: 15 (default 60) cache pressure: 100 (default) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 43.1 C mobo: N/A gpu: amdgpu temp: 41 C
Fan Speeds (RPM): N/A [/code]
This is just for info since I have given up booting Haiku on this machine
