Hello. I installed the recent mplayer package from HaikuDept. However, I get the following error when play any video:
mplayer Mazinger.mp4
MPlayer 1.1-4.8.4 (C) 2000-2012 MPlayer Team
3DNow supported but disabled
3DNowExt supported but disabled
Playing Mazinger.mp4.
libavformat version 54.6.100 (internal)
libavformat file format detected.
MPlayer interrupted by signal 4 in module: demux_open
- MPlayer crashed by an 'Illegal Instruction'.
It usually happens when you run it on a CPU different than the one it was
compiled/optimized for.
Verify this!
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
Is it possible to extract a debug report with Debugger in that situation, or does mplayer intercept the crash? It would be interesting to know which invalid instruction was hit (and which CPU model you have).
Apparently it doesn’t support SSE2. We try to not make use of SSE2 in Haiku for these CPUs. FFMPEG detects the CPU features at runtime and selects different variations of the code. I don’t know of mplayer can do this, it’s possible that it doesn’t, and try running SSE2 instructions for you.
It seems we need to tell mplayer how to use get_system_info (Haiku specific API) to get information about the CPU. On Linux it would look in /proc, but we don’t provide that.
It’s a bit more subtle than that. mplayer is perfectly capable of using CPUID on its own, the problem isn’t that mplayer can’t tell whether the CPU supports these instructions, but that it can’t tell whether it would be safe to use them with your OS. Exactly as written in the message.
A pre-emptively multi-tasking operating system takes responsibility for preserving the values of all the CPU registers during a context switch. Without this from the perspective of a userspace program the contents of registers could seemingly change suddenly from one instruction to the next without warning and writing programs would be impossible. Unlike its predecessor MMX, SSE adds completely new CPU registers. For compatibility reasons a new CPU instruction is used to preserve these registers during a context switch, older instructions for preserving register values do not include the SSE registers. Only an OS written (or updated) after the invention of SSE and with it in mind will therefore correctly preserve these values across context switches.
Thus, mplayer needs to be explicitly informed either that Haiku always correctly preserved SSE registers, or how to determine whether a particular version of Haiku will preserve these registers. Otherwise it has to assume that they won’t be preserved and thus it can’t really use SSE.
There are a bunch of clever optimisations possible in this space, but all mplayer cares about is whether SSE can be relied upon in Haiku. I would imagine the answer is simply “Yes” because Haiku is less than 15 years old.
