I’m running Haiku alphaR3 on VMWare player and I am having trouble downloading any software with WebPositive. I download from Haikuware, osdrawer.net, BeBits and Zetagames. The downloads usually start, but then only get 1/5 of the way downloaded and then stall. Otherwise WebPositive seems to work fine. Any ideas? Thanks,
I can still browse web pages. I just tried wget and it says “No space left on device” when i try to download Beshare (i hope i am doing it correctly) – so that means the hard drive of the vmware image of haiku is full, right? the icon for the hard drive in the upper left corner of the screen has a red stripe next to it…
The red bar on the disk icon means that you have run out of virtual disk space.
Create a new Disk Image in VMWare and then install Haiku on to it from the alpha3 image. Then you’ll be able to boot to that, install WebPositive and download files.
