Vice is a great commodore machine emulator, and it’s usually very easy to compile. I’ve had no problems compiling on linux and BeOS. When trying to compile on Haiku, it seems “configure” can’t figure out what type of machine/ or OS I’m using. I realize there are prebuilt VICE binaries for BeOS/Haiku, but I’d much rather compile it myself. Any suggestions? Thanks for any help. I’ve included the terminal output below:
~/Desktop> cd vice-2.1
~/Desktop/vice-2.1> ./configure
checking for a BSD-compatible install… /bin/install -c
checking whether build environment is sane… yes
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
checking build system type… ./config.guess: unable to guess system type
This script, last modified 2005-07-08, has failed to recognize
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
http://savannah.gnu.org/cgi-bin/viewcvs/checkout/config/config/config.guess
and
http://savannah.gnu.org/cgi-bin/viewcvs/checkout/config/config/config.sub
If the version you run (./config.guess) is already up to date, please
send the following data and any information you think might be
pertinent to config-patches@gnu.org in order to provide the needed
information to handle your system.
config.guess timestamp = 2005-07-08
uname -m = BePC
uname -r = 1
uname -s = Haiku
uname -v = r33109 Sep 12 2009 17:45:45
/usr/bin/uname -p =
/bin/uname -X =
hostinfo =
/bin/universe =
/usr/bin/arch -k =
/bin/arch =
/usr/bin/oslevel =
/usr/convex/getsysinfo =
UNAME_MACHINE = BePC
UNAME_RELEASE = 1
UNAME_SYSTEM = Haiku
UNAME_VERSION = r33109 Sep 12 2009 17:45:45
configure: error: cannot guess build type; you must specify one
