Ok, When I try and instal Beta4-64 on Oracle VM I can’t get past the opening splash screen (see attached image)
Beta 4 or Beta 5? Both should work.
What is the vm config you specified and version of vbox?
Thanks for your reply.
Oops! Sorry Beta 5,
Oracle Virtual Box Version 7.0.14 r161095 (Qt5.15.2)
I have it set up for OS type: Other/Other 64bit
Thanks
David
Yes indeed I got Beta5 up and running in Oracle VM.
