Tricked Haiku into Dual Monitor
Using a Display Port to 2 x HDMI Convertver i finally have multimon on haiku :wink:
The 2 FullHD HDMI Displays show up as one double width Display Port Monitor (3840x1080) in Haiku boot menu. Haiku boot Icons show in the middle of the 2 screens, but Display gets black after that.
(can someone explain why?).
If I choose 3840x1080 32Bit and Safe Graphics i get one BIG Desktop
When you say display get black after that, do you mean both screens are turning black or is it only one? You should have a look at the syslogs both in safe mode and when it doesn’t work and compare. Perhaps you will find your answer.
Both turn black, can do the syslog on the weekend hopefully, but it is WORKING :wink: (sort of)
This is the time when the graphics driver initialize. So, probably it failed to initialize correctly. If you can extract a syslog it would indeed be very interesting to se ewhat happened, as this should not be a problem. Maybe it is an easy fix (especially if the setup works with a single, “normal” display).
Do i access the logs after restart (which logfile are we talking about ?), or should i set up ssh
This should work:
  • Delete all files in /var/log/syslog
  • Reboot without using failsafe mode, get a black screen
  • Press the power button once, let the machine shut down cleanly
  • Reboot with failsafe graphics again
  • Get all the files from /var/log/syslog, this should include the boot attempt with black screen, as well as the reboot in failsafe graphics
No SSH needed.
KERN: options = 0
KERN: No APM available.
KERN: smp: using ACPI to detect MP configuration
KERN: smp: local apic address is 0xfee00000
KERN: smp: found local APIC with id 0
KERN: smp: found local APIC with id 1
KERN: smp: found local APIC with id 2
KERN: smp: found local APIC with id 3
KERN: smp: APIC is disabled and will not be used
KERN: smp: found io APIC with id 2 and address 0xfec00000
KERN: VESA version = 3.0, capabilities 1
KERN: OEM string: Intel(R) Sandybridge/Ivybridge Graphics Chipset Accelerated VGA BIOS
KERN:  0x160: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN: 	mask: r: 0 0 g: 0 0 b: 0 0 dcmi: 0
KERN:  0x161: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x162: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x163: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x164: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x165: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x166: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x167: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x168: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x169: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16a: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16b: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16c: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16d: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16e: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x16f: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x170: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x171: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x13c: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x14d: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x15c: 0 x 0 x 0 (a = 0, mem = 0, phy = 0, p = 0, b = 0)
KERN:  0x13a: 1600 x 1200 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x14b: 1600 x 1200 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN: 	mask: r: 5 11 g: 6 5 b: 5 0 dcmi: 0
KERN:  0x15a: 1600 x 1200 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN: 	mask: r: 8 16 g: 8 8 b: 8 0 dcmi: 0
KERN:  0x107: 1280 x 1024 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x11a: 1280 x 1024 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x11b: 1280 x 1024 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x105: 1024 x 768 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x117: 1024 x 768 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x118: 1024 x 768 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x112: 640 x 480 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x114: 800 x 600 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x115: 800 x 600 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x101: 640 x 480 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x103: 800 x 600 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x111: 640 x 480 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x17d: 3840 x 1080 x 8 (a = 155, mem = 4, phy = c0000000, p = 1, b = 1)
KERN:  0x17e: 3840 x 1080 x 16 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN:  0x17f: 3840 x 1080 x 32 (a = 155, mem = 6, phy = c0000000, p = 1, b = 1)
KERN: Using mode 0x118
KERN: VESA compatible graphics!
KERN: EDID1: 4f
KERN: EDID2: ebx 102
KERN: EDID3: 4f
KERN: EDID info:
KERN:   Vendor: VPY
KERN:   Product ID: 389
KERN:   Serial #: 0
KERN:   Produced in week/year: 1/2010
KERN:   EDID version: 1.4
KERN:   Type: Digital
KERN:   Digital Bit Depth: 8
KERN:   Size: 0 cm x 0 cm
KERN:   Gamma=2.2
KERN:   White (X,Y)=(0.313,0.329)
KERN: Supported Future Video Modes:
KERN: 1152x864@75Hz (id=20337)
KERN: 1280x1024@60Hz (id=32897)
KERN: 1600x900@60Hz (id=49321)
KERN: 1600x1200@60Hz (id=16553)
KERN: 1920x1080@60Hz (id=49361)
Last message repeated 1 time
KERN: Supported VESA Video Modes:
KERN: 720x400@70Hz
KERN: 640x480@60Hz
KERN: 640x480@75Hz
KERN: 800x600@60Hz
KERN: 800x600@75Hz
KERN: 1024x768@60Hz
KERN: 1024x768@75Hz
KERN: 1280x1024@75Hz
KERN: Additional Video Mode (3840x1080@59Hz):
KERN: clock=277.54 MHz
KERN: h: (3840, 3928, 3972, 4120)
KERN: v: (1080, 1084, 1089, 1125)
KERN: size: 25.5 cm x 25.5 cm
KERN: border: 0 cm x 0 cm
KERN: Additional Video Mode (2560x1024@59Hz):
KERN: clock=189.449 MHz
KERN: h: (2560, 2608, 2720, 2968)
KERN: v: (1024, 1025, 1028, 1066)
KERN: Monitor Name: Dual HDMI
KERN: Additional Video Mode (1600x600@59Hz):
KERN: clock=69.79 MHz
KERN: h: (1600, 1640, 1768, 1856)
KERN: v: (600, 601, 605, 628)
KERN: crtc: h 3928/3972/4120, v 1084/1089/1125, pixel clock 277540000, refresh 6014
KERN: Welcome to the Haiku boot loader!
KERN: Haiku revision: hrev56578+93
KERN: number of drives: 1
KERN: add_partitions_for(0x001053c0, mountFS = no)
KERN: add_partitions_for(fd = 0, mountFS = no)
KERN: 0x00105528 Partition::Partition
KERN: 0x00105528 Partition::Scan()
KERN: check for partitioning_system: GUID Partition Map
KERN: check for partitioning_system: Intel Partition Map
KERN:   priority: 810
KERN: check for partitioning_system: Intel Extended Partition
KERN: 0x001056a8 Partition::Partition
KERN: 0x00105528 Partition::AddChild 0x001056a8
KERN: 0x001056a8 Partition::SetParent 0x00105528
KERN: new child partition!
KERN: 0x00105770 Partition::Partition
KERN: 0x00105528 Partition::AddChild 0x00105770
KERN: 0x00105770 Partition::SetParent 0x00105528
KERN: 0x00105528 Partition::Scan(): scan child 0x001056a8 (start = 32768, size = 45256540160, parent = 0x00105528)!
KERN: 0x001056a8 Partition::Scan()
KERN: 0x00105528 Partition::Scan(): scan child 0x00105770 (start = 87199612928, size = 92845113344, parent = 0x00105528)!
KERN: 0x00105770 Partition::Scan()
KERN: 0x00105528 Partition::~Partition
KERN: 0x001056a8 Partition::SetParent 0x00000000
KERN: 0x00105770 Partition::SetParent 0x00000000
KERN: boot partition offset: 32768
KERN: 0x001056a8 Partition::_Mount check for file_system: BFS Filesystem
KERN: PackageVolumeInfo::SetTo()
KERN: load kernel kernel_x86_64...
KERN: video mode: 3840x1080x32
KERN: unhandled pheader type 0x6474e550
Last message repeated 20 times
KERN: unhandled pheader type KERN: 0x6474e550
Last message repeated 29 times
KERN: ucode_load: system/data/firmware/intel-ucode/06-3a-09
KERN: ucode_load: couldn't find microcode
KERN: maximum boot loader heap usage: 584816, currently used: 573904
KERN: smp: found 4 cpus
KERN: smp: apic_phys = 0xfee00000
KERN: smp: ioapic_phys = 0xfec00000
KERN: smp: apic (mapped) = 0x82883000
KERN: APIC ticks/sec = 99732931
KERN: GDT at 0x598e0
KERN: phys memory ranges:
KERN:     base 0x0000000000100000, length 0x000000001ff00000
KERN:     base 0x0000000020200000, length 0x000000001fe04000
KERN:     base 0x0000000040005000, length 0x000000006ed2c000
KERN:     base 0x0000000100000000, length 0x000000013e600000
KERN: allocated phys memory ranges:
KERN:     base 0x0000000000100000, length 0x0000000003a5d000
KERN:     base 0x0000000003f00000, length 0x0000000000100000
KERN: allocated virt memory ranges:
KERN:     base 0xffffffff80000000, length 0x0000000002891000
KERN: kernel args ranges:
KERN:     base 0xffffffff81109000, length 0x000000000006b000
KERN:     base 0xffffffff82146000, length 0x000000000002e000
KERN:     base 0xffffffff821bf000, length 0x0000000000010000
KERN:     base 0xffffffff82225000, length 0x0000000000010000
KERN:     base 0xffffffff82244000, length 0x0000000000010000
KERN:     base 0xffffffff8231f000, length 0x000000000002e000
KERN:     base 0xffffffff82585000, length 0x0000000000010000
KERN:     base 0xffffffff825e4000, length 0x0000000000010000
KERN:     base 0xffffffff82637000, length 0x0000000000010000
KERN:     base 0xffffffff8267d000, length 0x0000000000010000
KERN:     base 0xffffffff826e5000, length 0x0000000000010000
KERN:     base 0xffffffff8271d000, length 0x0000000000010000
KERN:     base 0xffffffff827c4000, length 0x000000000001d000
KERN:     base 0xffffffff82805000, length 0x0000000000010000
KERN:     base 0xffffffff8286f000, length 0x0000000000010000
KERN: kernel entry at 0xffffffff800639f0
KERN: trampolining other cpus
KERN: wait for delivery
KERN: deassert INIT
KERN: num startups = 2
KERN: send STARTUP
KERN: send STARTUP
KERN: deassert INIT
KERN: send STARTUP
KERN: send STARTUP
KERN: deassert INIT
KERN: send STARTUP
KERN: send STARTUP
KERN: done trampolining
KERN: Welcome to kernel debugger output!
KERN: Haiku revision: hrev56578+93, debug level: 1
KERN: CPU: no microcode provided
KERN: CPU 0: type 0 family 6 extended_family 0 model 10 extended_model 3 stepping 9, string 'GenuineIntel'
KERN: CPU 0: vendor 'Intel' model name 'Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz'
KERN: CPU 0: apic id 0, package 0, core 0, smt 0
KERN: CPU 0: cache sharing: L1 id 0, L2 id 0, L3 id 0
KERN: CPU 0: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh ds acpi mmx fxsr sse sse2 ss htt tm pbe sse3 pclmulqdq dtes64 monitor dscpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tscdeadline aes xsave avx f16c rdrnd syscall nx long dts itb arat pln ecmd ptm aperfmperf epb smep erms ibrs stibp l1d_flush ssbd xsaveopt
KERN: CPU 0: patch_level 33
KERN: reserve_io_interrupt_vectors: reserved 16 vectors starting from 0
KERN: mark_page_range_in_use(0x0, 0x100): start page is before free list
KERN: mark_page_range_in_use(0x0, 0xa0): start page is before free list
KERN: Welcome to syslog debug output!
KERN: mapping local apic at 0xffffffff82883000
KERN: enable SMEP
KERN: arch_altcodepatch_replace found 2 altcodepatches for tag 3
KERN: arch_altcodepatch_replace found 4 altcodepatches for tag 4
KERN: enable XSAVE 0x7 832
KERN: CPU 1: type 0 family 6 extended_family 0 model 10 extended_model 3 stepping 9, string 'GenuineIntel'
KERN: CPU 3: type 0 family 6 extended_family 0 model 10 extended_model 3 stepping 9, string 'GenuineIntel'
KERN: CPU 2: type 0 family 6 extended_family 0 model 10 extended_model 3 stepping 9, string 'GenuineIntel'
KERN: CPU 1: vendor 'Intel' model name 'Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz'
KERN: CPU 3: vendor 'Intel' model name 'Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz'
KERN: CPU 2: vendor 'Intel' model name 'Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz'
KERN: CPU 1: apic id 1, package 0, core 0, smt 1
KERN: CPU 3: apic id 3, package 0, core 1, smt 1
KERN: CPU 2: apic id 2, package 0, core 1, smt 0
KERN: CPU 1: cache sharing: L1 id 0, L2 id 0, L3 id 0
KERN: CPU 2: cache sharing: L1 id 2, L2 id 2, L3 id 0
KERN: CPU 3: cache sharing: L1 id 2, L2 id 2, L3 id 0
KERN: CPU 1: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh ds acpi mmx fxsr sse sse2 ss htt tm pbe sse3 pclmulqdq dtes64 monitor dscpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tscdeadline aes xsave osxsave avx f16c rdrnd syscall nx long dts itb arat pln ecmd ptm aperfmperf epb smep erms ibrs stibp l1d_flush ssbd xsaveopt
KERN: CPU 1: patch_level 33
KERN: CPU 3: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh ds acpi mmx fxsr sse sse2 ss htt tm pbe sse3 pclmulqdq dtes64 monitor dscpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tscdeadline aes xsave osxsave avx f16c rdrnd syscall nx long dts itb arat pln ecmd ptm aperfmperf epb smep erms ibrs stibp l1d_flush ssbd xsaveopt
KERN: CPU 2: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh ds acpi mmx fxsr sse sse2 ss htt tm pbe sse3 pclmulqdq dtes64 monitor dscpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tscdeadline aes xsave osxsave avx f16c rdrnd syscall nx long dts itb arat pln ecmd ptm aperfmperf epb smep erms ibrs stibp l1d_flush ssbd xsaveopt
KERN: CPU 3: patch_level 33
KERN: CPU 2: patch_level 33
KERN: setting up apic for CPU 0: apic id 0, version 17170453
KERN: CPU 0: logical apic id: 0x1
KERN: x86_init_fpu: CPU has SSE... enabling FXSR and XMM.
KERN: reserve_io_interrupt_vectors: reserved 3 vectors starting from 221
KERN: reserve_io_interrupt_vectors: reserved 1 vectors starting from 219
KERN: arch_init_timer: using APIC timer.
KERN: allocate_commpage_entry(2, 16) -> 0x0000000000000200
KERN: scheduler_init: found 4 logical cpus and 3 cache levels
KERN: scheduler switches: single core: false, cpu load tracking: false, core load tracking: true
KERN: scheduler: switching to low latency mode
KERN: msi support enabled
KERN: PCI: pci_module_init
KERN: PCI: mechanism addr: f8000000, seg: 0, start: 0, end: 3f
KERN: PCI: mechanism pcie controller found
KERN: PCI: FixupDevices: checking bus 2 behind 8086:1e10
KERN: PCI: FixupDevices: checking bus 3 behind 8086:1e12
KERN: PCI: FixupDevices: checking bus 4 behind 8086:1e14
KERN: PCI: FixupDevices: checking bus 12 behind 8086:1e18
KERN: PCI: dom 0, bus 0, dev 28, func 0, changed PCI bridge control from 0x0000 to 0x0003
KERN: PCI: dom 0, bus 0, dev 28, func 1, changed PCI bridge control from 0x0000 to 0x0003
KERN: PCI: dom 0, bus 0, dev 28, func 2, changed PCI bridge control from 0x0000 to 0x0003
KERN: PCI: dom 0, bus 0, dev 28, func 4, changed PCI bridge control from 0x0000 to 0x0003
KERN: PCI: [dom 0, bus  0] bus   0, device  0, function  0: vendor 8086, device 0154, revision 09
KERN: PCI:   class_base 06, class_function 00, class_api 00
KERN: PCI:   vendor 8086: Intel Corporation
KERN: PCI:   device 0154: 3rd Gen Core processor DRAM Controller
KERN: PCI:   info: Bridge (Host bridge)
KERN: PCI:   line_size 00, latency 00, header_type 00, BIST 00
KERN: PCI:   ROM base host 00000000, pci 00000000, size 00000000
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 21fb, subsystem_vendor_id 17aa
KERN: PCI:   interrupt_line 00, interrupt_pin 00, min_grant 00, max_latency 00
KERN: PCKERN: I:   base reg 0: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 1: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 2: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 3: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 4: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 5: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   Capabilities: vendspec
KERN: PCI: [dom 0, bus  0] bus   0, device  2, function  0: vendor 8086, device 0166, revision 09
KERN: PCI:   class_base 03, class_function 00, class_api 00
KERN: PCI:   device 0166: 3rd Gen Core processor Graphics Controller
KERN: PCI:   info: Display controller (VGA compatible controller, VGA controller)
KERN: PCI:   interrupt_line 0b, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000d0000000, pci 00000000d0000000, size 00400000, flags 04 00
KERN: PCI:   base reg 2: host 00000000c0000000, pci 00000000c0000000, size 10000000, flags 0c 00
KERN: PCI:   base reg 4: host 00006000, pci 00006000, size 00000040, flags 01
KERN: PCI:   Capabilities: MSI, PM, AdvancedFeatures
KERN: PCI: [dom 0, bus  0] bus   0, device 20, function  0: vendor 8086, device 1e31, revision 04
KERN: PCI:   class_base 0c, class_function 03, class_api 30
KERN: PCI:   device 1e31: 7 Series/C210 Series Chipset Family USB xHCI Host Controller
KERN: PCI:   info: Serial bus controller (USB controller, XHCI)
KERN: PCI:   base reg 0: host 00000000d2520000, pci 00000000d2520000, size 00010000, flags 04 00
KERN: PCI:   Capabilities: PM, MSI
KERN: PCI: [dom 0, bus  0] bus   0, device 22, function  0: vendor 8086, device 1e3a, revision 04
KERN: PCI:   class_base 07, class_function 80, class_api 00
KERN: PCI:   device 1e3a: 7 Series/C216 Chipset Family MEI Controller #1
KERN: PCI:   info: Communication controller
KERN: PCI:   line_size 00, latency 00, header_type 80, BIST 00
KERN: PCI:   base reg 0: host 00000000d2535000, pci 00000000d2535000, size 00000010, flags 04 00
KERN: PCI: [dom 0, bus  0] bus   0, device 22, function  3: vendor 8086, device 1e3d, revision 04
KERN: PCI:   class_base 07, class_function 00, class_api 02
KERN: PCI:   device 1e3d: 7 Series/C210 Series Chipset Family KT Controller
KERN: PCI:   info: Communication controller (Serial controller, 16550)
KERN: PCI:   interrupt_line 0a, interrupt_pin 02, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 000060b0, pci 000060b0, size 00000008, flags 01
KERN: PCI:   base reg 1: host d253c000, pci d253c000, size 00001000, flags 00
KERN: PCI: [dom 0, bus  0] bus   0, device 25, function  0: vendor 8086, device 1502, revision 04
KERN: PCI:   class_base 02, class_function 00, class_api 00
KERN: PCI:   device 1502: 82579LM Gigabit Network Connection (Lewisville)
KERN: PCI:   info: Network controller (Ethernet controller)
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 21f3, subsystem_vendor_id 17aa
KERN: PCI:   base reg 0: host d2500000, pci d2500000, size 00020000, flags 00
KERN: PCI:   base reg 1: host d253b000, pci d253b000, size 00001000, flags 00
KERN: PCI:   base reg 2: host 00006080, pci 00006080, size 00000020, flags 01
KERN: PCI:   Capabilities: PM, MSI, AdvancedFeatures
KERN: PCI: [dom 0, bus  0] bus   0, device 26, function  0: vendor 8086, device 1e2d, revision 04
KERN: PCI:   class_base 0c, class_function 03, class_api 20
KERN: PCI:   device 1e2d: 7 Series/C216 Chipset Family USB Enhanced Host Controller #2
KERN: PCI:   info: Serial bus controller (USB controller, EHCI)
KERN: PCI:   base reg 0: host d253a000, pci d253a000, size 00000400, flags 00
KERN: PCI:   Capabilities: PM, DebugPort, AdvancedFeatures
KERN: PCI: [dom 0, bus  0] bus   0, device 27, function  0: vendor 8086, device 1e20, revision 04
KERN: PCI:   class_base 04, class_function 03, class_api 00
KERN: PCI:   device 1e20: 7 Series/C216 Chipset Family High Definition Audio Controller
KERN: PCI:   info: Multimedia controller (Audio device)
KERN: PCI:   line_size 10, latency 00, header_type 00, BIST 00
KERN: PCI:   interrupt_line 0a, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000d2530000, pci 00000000d2530000, size 00004000, flags 04 00
KERN: PCI:   Capabilities: PM, MSI, PCIe
KERN: PCI:   Extended capabilities: Virtual Channel, Root Complex Link Declaration
KERN: PCI: [dom 0, bus  0] bus   0, device 28, function  0: vendor 8086, device 1e10, revision c4
KERN: PCI:   class_base 06, class_function 04, class_api 00
KERN: PCI:   device 1e10: 7 Series/C216 Chipset Family PCI Express Root Port 1
KERN: PCI:   info: Bridge (PCI bridge, Normal decode)
KERN: PCI:   line_size 10, latency 00, header_type 81, BIST 00
KERN: PCI:   subsystem_id 0000, subsystem_vendor_id 0040
KERN: PCI:   primary_bus 00, secondary_bus 02, subordinate_bus 02, secondary_latency 00
KERN: PCI:   I/O window 5000-5fff
KERN: PCI:   memory wKERN: indow d1d00000-d24fffff
KERN: PCI:   prefetchable memory window 00000000d0400000-00000000d0bfffff
KERN: PCI:   bridge_control 0003, secondary_status 0000
KERN: PCI:   ROM base host 00000000, pci 00000000, size ??
KERN: PCI:   base reg 0: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   Capabilities: PCIe, MSI, subvendor, PM
KERN: PCI:   Extended capabilities: (empty list)
KERN: PCI: [dom 0, bus  0] bus   0, device 28, function  1: vendor 8086, device 1e12, revision c4
KERN: PCI:   device 1e12: 7 Series/C210 Series Chipset Family PCI Express Root Port 2
KERN: PCI:   primary_bus 00, secondary_bus 03, subordinate_bus 03, secondary_latency 00
KERN: PCI:   I/O window f000-0fff
KERN: PCI:   memory window d1c00000-d1cfffff
KERN: PCI:   prefetchable memory window fffffffffff00000-00000000000fffff
KERN: PCI:   interrupt_line 07, interrupt_pin 02
KERN: PCI: [dom 0, bus  3] bus   3, device  0, function  0: vendor 8086, device 0085, revision 34
KERN: PCI:   class_base 02, class_function 80, class_api 00
KERN: PCI:   device 0085: Centrino Advanced-N 6205 [Taylor Peak] (Centrino Advanced-N 6205 (802.11a/b/g/n))
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 1311, subsystem_vendor_id 8086
KERN: PCI:   interrupt_line 07, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000d1c00000, pci 00000000d1c00000, size 00002000, flags 04 00
KERN: PCI:   Extended capabilities: Advanced Error Reporting, Serial Number
KERN: PCI: [dom 0, bus  0] bus   0, device 28, function  2: vendor 8086, device 1e14, revision c4
KERN: PCI:   device 1e14: 7 Series/C210 Series Chipset Family PCI Express Root Port 3
KERN: PCI:   primary_bus 00, secondary_bus 04, subordinate_bus 0b, secondary_latency 00
KERN: PCI:   I/O window 4000-4fff
KERN: PCI:   memory window d1400000-d1bfffff
KERN: PCI:   prefetchable memory window 00000000d0c00000-00000000d13fffff
KERN: PCI:   interrupt_line 0b, interrupt_pin 03
KERN: PCI: [dom 0, bus  4] bus   4, device  0, function  0: vendor 1180, device e823, revision 04
KERN: PCI:   class_base 08, class_function 80, class_api 00
KERN: PCI:   vendor 1180: Ricoh Co Ltd
KERN: PCI:   device e823: PCIe SDXC/MMC Host Controller
KERN: PCI:   info: Generic system peripheral
KERN: PCI:   line_size 10, latency 00, header_type 80, BIST 00
KERN: PCI:   base reg 0: host d1400000, pci d1400000, size 00000100, flags 00
KERN: PCI:   Capabilities: MSI, PM, PCIe
KERN: PCI:   Extended capabilities: Virtual Channel, Advanced Error Reporting
KERN: PCI: [dom 0, bus  0] bus   0, device 28, function  4: vendor 8086, device 1e18, revision c4
KERN: PCI:   device 1e18: 7 Series/C210 Series Chipset Family PCI Express Root Port 5
KERN: PCI:   primary_bus 00, secondary_bus 0c, subordinate_bus 3f, secondary_latency 00
KERN: PCI:   I/O window 8000-dfff
KERN: PCI:   memory window e0000000-e7ffffff
KERN: PCI:   prefetchable memory window 00000000e8000000-00000000f7ffffff
KERN: PCI: [dom 0, bus  0] bus   0, device 29, function  0: vendor 8086, device 1e26, revision 04
KERN: PCI:   device 1e26: 7 Series/C216 Chipset Family USB Enhanced Host Controller #1
KERN: PCI:   base reg 0: host d2539000, pci d2539000, size 00000400, flags 00
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  0: vendor 8086, device 1e55, revision 04
KERN: PCI:   class_base 06, class_function 01, class_api 00
KERN: PCI:   device 1e55: QM77 Express Chipset LPC Controller
KERN: PCI:   info: Bridge (ISA bridge)
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  2: vendor 8086, device 1e03, revision 04
KERN: PCI:   class_base 01, class_function 06, class_api 01
KERN: PCI:   device 1e03: 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
KERN: PCI:   info: Mass storage controller (SATA controller, AHCI 1.0)
KERN: PCI:   ROM base host 00000000, pKERN: ci 00000000, size 00000000
KERN: PCI:   base reg 0: host 000060a8, pci 000060a8, size 00000008, flags 01
KERN: PCI:   base reg 1: host 000060bc, pci 000060bc, size 00000004, flags 01
KERN: PCI:   base reg 2: host 000060a0, pci 000060a0, size 00000008, flags 01
KERN: PCI:   base reg 3: host 000060b8, pci 000060b8, size 00000004, flags 01
KERN: PCI:   base reg 4: host 00006060, pci 00006060, size 00000020, flags 01
KERN: PCI:   base reg 5: host d2538000, pci d2538000, size 00000800, flags 00
KERN: PCI:   Capabilities: MSI, PM, SATA, AdvancedFeatures
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  3: vendor 8086, device 1e22, revision 04
KERN: PCI:   class_base 0c, class_function 05, class_api 00
KERN: PCI:   device 1e22: 7 Series/C216 Chipset Family SMBus Controller
KERN: PCI:   info: Serial bus controller (SMBus)
KERN: PCI:   interrupt_line 0b, interrupt_pin 03, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000d2534000, pci 00000000d2534000, size 00000100, flags 04 00
KERN: PCI:   base reg 4: host 0000efa0, pci 0000efa0, size 00000020, flags 01
KERN: PCI:   Capabilities: (not supported)
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 21fb, subsystem_vendor_id KERN: 17aa
KERN: PCI:   memory window d1d00000-d24fffff
KERN: PCI:   info: Serial bus controller (USB controlleKERN: r, EHCI)
KERN: ACPI: RSDP 0x00000000000F0120 000024 (v02 LENOVO)
KERN: ACPI: XSDT 0x00000000BAFFE170 0000C4 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: FACP 0x00000000BAFE5000 00010C (v05 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: DSDT 0x00000000BAFE7000 01109F (v01 LENOVO TP-G7    00002760 INTL 20061109)
KERN: ACPI: FACS 0x00000000BAF5A000 000040
KERN: ACPI: SLIC 0x00000000BAFFD000 000176 (v01 LENOVO TP-G7    00002760 PTL  00000001)
KERN: ACPI: TCPA 0x00000000BAFFC000 000032 (v02 PTL    LENOVO   06040000 LNVO 00000001)
KERN: ACPI: SSDT 0x00000000BAFFB000 000408 (v01 LENOVO TP-SSDT2 00000200 INTL 20061109)
KERN: ACPI: SSDT 0x00000000BAFFA000 000033 (v01 LENOVO TP-SSDT1 00000100 INTL 20061109)
KERN: ACPI: SSDT 0x00000000BAFF9000 000797 (v01 LENOVO SataAhci 00001000 INTL 20061109)
KERN: ACPI: HPET 0x00000000BAFE3000 000038 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: APIC 0x00000000BAFE2000 000098 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: MCFG 0x00000000BAFE1000 00003C (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: ECDT 0x00000000BAFE0000 000052 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: FPDT 0x00000000BAFDF000 000064 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: ASF! 0x00000000BAFE6000 0000A5 (v32 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: UEFI 0x00000000BAFDE000 00003E (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: UEFI 0x00000000BAFDD000 000042 (v01 PTL    COMBUF   00000001 PTL  00000001)
KERN: ACPI: POAT 0x00000000BAFDC000 000055 (v03 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: SSDT 0x00000000BAFDB000 000BF3 (v01 PmRef  Cpu0Ist  00003000 INTL 20061109)
KERN: ACPI: SSDT 0x00000000BAFDA000 000A83 (v01 PmRef  CpuPm    00003000 INTL 20061109)
KERN: ACPI: DMAR 0x00000000BAFD9000 0000B8 (v01 INTEL  SNB      00000001 INTL 00000001)
KERN: ACPI: UEFI 0x00000000BAFD8000 000292 (v01 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: DBG2 0x00000000BAFD7000 0000E9 (v00 LENOVO TP-G7    00002760 PTL  00000002)
KERN: ACPI: Forced DSDT copy: length 0x1109F copied locally, original unmapped
KERN: ACPI: 6 ACPI AML tables successfully acquired and loaded
KERN: ACPI Error: No handler for Region [ECOR] (0xffffffff8332c3d8) [EmbeddedControl] (20210105/evregion-290)
KERN: ACPI Error: Region EmbeddedControl (ID=3) has no handler (20210105/exfldio-428)
KERN: ACPI Error: Aborting method \_SB.PCI0.LPC.EC.AC._PSR due to previous error (AE_NOT_EXIST) (20210105/psparse-688)
KERN: ACPI Error: Aborting method \_SB._INI due to previous error (AE_NOT_EXIST) (20210105/psparse-688)
KERN: ACPI Error: Aborting method \_SB.LID._LID due to previous error (AE_NOT_EXIST) (20210105/psparse-688)
KERN: ACPI Error: Aborting method \_SB.PCI0.VID._INI due to previous error (AE_NOT_EXIST) (20210105/psparse-688)
KERN: ACPI Error: Aborting method \_SB.PCI0.LPC.EC._INI due to previous error (AE_NOT_EXIST) (20210105/psparse-688)
KERN: ACPI: Enabled 7 GPEs in block 00 to 3F
KERN: found io-apic with address 0xfec00000, global interrupt base 0, apic-id 2
KERN: mapping io-apic 0 at physical address 0xfec00000
KERN: io-apic 0 has range 0-23, 24 entries, version 0x00170020, apic-id 2
KERN: setting ACPI interrupt model to APIC
KERN: IRQ routing table with 15 entries
KERN: address 0x2ffff; pin 0; GSI 16; pci 0:2 pin 1 func mask 1; bios irq: 11; gsi 16; config 0x06
KERN: address 0x14ffff; pin 0; GSI 16; pci 0:20 pin 1 func mask 1; bios irq: 11; gsi 16; config 0x06
KERN: address 0x16ffff; pin 0; GSI 16; pci 0:22 pin 1 func mask 1; bios irq: 11; gsi 16; config 0x06
KERN: address 0x16ffff; pin 1; GSI 19; pci 0:22 pin 2 func mask 8; bios irq: 10; gsi 19; config 0x06
KERN: address 0x19ffff; pin 0; GSI 20; pci 0:25 pin 1 func mask 1; bios irq: 11; gsi 20; config 0x06
KERN: address 0x1affff; pin 0; GSI 16; pci 0:26 pin 1 func mask 1; bios irq: 11; gsi 16; config 0x06
KERN: address 0x1bffff; pin 0; GSI 22; pci 0:27 pin 1 func mask 1; bios irq: 10; gsi 22; config 0x06
KERN: address 0x1cffff; pin 0; GSI 16; pci 0:28 pin 1 func mask 11; bios irq: 11; gsi 16; config 0x06
KERN: address 0x1cffff; pin 1; GSI 17; pci 0:28 pin 2 func mask 2; bios irq: 7; gsi 17; config 0x06
KERN: address 0x1cffff; pin 2; GSI 18; pci 0:28 pin 3 func mask 4; bios irq: 11; gsi 1KERN: 8; config 0x06
KERN: address 0x1dffff; pin 0; GSI 23; pci 0:29 pin 1 func mask 1; bios irq: 10; gsi 23; config 0x06
KERN: address 0x1fffff; pin 1; GSI 19; pci 0:31 pin 2 func mask 4; bios irq: 10; gsi 19; config 0x06
KERN: address 0x1fffff; pin 2; GSI 18; pci 0:31 pin 3 func mask 8; bios irq: 11; gsi 18; config 0x06
KERN: address 0xffff; pin 0; GSI 17; pci 3:0 pin 1 func mask 1; bios irq: 7; gsi 17; config 0x06
KERN: address 0xffff; pin 0; GSI 18; pci 4:0 pin 1 func mask 1; bios irq: 11; gsi 18; config 0x06
KERN: found interrupt override for bus 0, source irq 0, global irq 2, flags 0x00000000
KERN: found interrupt override for bus 0, source irq 9, global irq 9, flags 0x0000000d
KERN: free_io_interrupt_vectors: freeing 16 vectors starting from 0
KERN: reserve_io_interrupt_vectors: reserved 24 vectors starting from 0
KERN: using io-apics for interrupt routing
KERN: setting up apic for CPU 1: apic id 1, version 17170453
KERN: setting up apic for CPU 2: apic id 2, version 17170453
KERN: setting up apic for CPU 3: apic id 3, version 17170453
KERN: CPU 2: logical apic id: 0x4
KERN: CPU 3: logical apic id: 0x8
KERN: CPU 1: logical apic id: 0x2
KERN: allocate_commpage_entry(3, 69) -> 0x0000000000000210
KERN: slab memory manager: created area 0xffffffff80801000 (467)
KERN: publish device: node 0xffffffff83024820, path acpi/namespace, module bus_managers/acpi/namespace/device_v1
KERN: publish device: node 0xffffffff83024820, path acpi/call, module bus_managers/acpi/call/device_v1
KERN: registering power button
KERN: slab memory manager: created area 0xffffffff81801000 (621)
KERN: publish device: node 0xffffffff8347d970, path power/embedded_controller/0, module drivers/power/acpi_embedded_controller/device_v1
KERN: usb xhci -1: interface version: 0x0100
KERN: usb xhci -1: structural parameters: 1:0x08000820 2:0x84000054 3:0x0200000a
KERN: usb xhci -1: capability parameters: 0x20007181
KERN: allocate_io_interrupt_vectors: allocated 1 vectors starting from 24
KERN: msi_allocate_vectors: allocated 1 vectors starting from 24
KERN: msi enabled: 0x0087
KERN: usb xhci -1: using message signaled interrupts
KERN: usb xhci -1: starting XHCI host controller
KERN: usb xhci -1: successfully started the controller
KERN: usb hub 2: port 1: new device connected
KERN: usb ehci -1: successfully took ownership of the host controller
KERN: sitd entry size 128, itd entry size 128
KERN: usb ehci -1: successfully started the controller
KERN: e[33msdhci_pci:e[0m supports_device(vid:8086 pid:1e22)
KERN: usb hub 2: port 3: new device connected
KERN: usb hub 2: port 4 was warm reset
KERN: usb hub 2: port 5 was warm reset
KERN: usb hub 2: port 6 was warm reset
KERN: usb hub 2: port 7 was warm reset
KERN: usb hub 7: port 0: new device connected
KERN: usb hub 80: port 0: new device connected
KERN: usb hub 80: port 3: new device connected
KERN: usb hub 80: port 5: new device connected
KERN: usb hub 12: port 0: new device connected
KERN: usb hub 124: port 4: new device connected
KERN: get_boot_partitions(): boot volume message:
KERN: KMessage: buffer: 0xffffffff8287e9f0 (size/capacity: 347/347), flags: 0xa
KERN:   field: "booted from image" (BOOL): false
KERN:   field: "partition offset"  (LLNG): 32768 (0x8000)
KERN:   field: "packaged"          (BOOL): true
KERN:   field: "boot method"       (LONG): 0 (0x0)
KERN:   field: "boot drive number" (LLNG): 128 (0x80)
KERN:   field: "disk identifier"   (RAWT): data at 0xffffffff8287eafc, 79 bytes
KERN: get_boot_partitions(): boot method type: 0
KERN: intel: ep_std_ops(0x1)
KERN: intel: ep_std_ops(0x2)
KERN: intel: pm_std_ops(0x1)
KERN: intel: pm_std_ops(0x2)
KERN: dos_std_ops()
KERN: e[33msdhci_pci:e[0m supports_device(vid:1180 pid:e823)
KERN: e[33msdhci_pci:e[0m SDHCI Device found! Subtype: 0x0080, type: 0x0008
KERN: e[33msdhci_pci:e[0m CALLED status_t init_device(device_node*, void**)
KERN: e[33msdhci_pci:e[0m Device ID after Ricoh quirk: e822
KERN: e[33msdhci_pci:e[0m CALLED status_t register_child_devices(void*)
KERN: e[33msdhci_pci:e[0m register_child_devices: 0, 1
KERN: e[33msdhci_pci:e[0m CALLED status_t init_bus(device_node*, void**)
KERN: e[33msdhci_pci:e[0m Register SD bus at slot 1, using bar 0
KERN: e[33msdhci_pci:e[0m irq interrupt line: 18
KERN: e[33msdhci_pci:e[0m Card not inserted, not powering on for now
KERN: e[33mmmc_bus:e[0m CALLED status_t mmc_bus_added_device(device_node*)
KERN: e[33mmmc_bus:e[0m CALLED status_t mmc_bus_init(device_node*, void**)
KERN: e[33mmmc_bus:e[0m CALLED MMCBus::MMCBus(device_node*)
KERN: e[33msdhci_pci:e[0m CALLED void set_scan_semaphore(void*, sem_id)
KERN: e[33mmmc_bus:e[0m MMC bus object created
KERN: e[33mmmc_disk:e[0m CALLED float mmc_disk_supports_device(device_node*)
KERN: e[33mmmc_disk:e[0m Could not get device type
KERN: ahci: generic AHCI controller found! vendor 0x8086, device 0x1e03
KERN: ahci: ahci_register_device
KERN: ahci: ahci_init_driver
KERN: ahci: ahci_sim_init_bus
KERN: ahci: ahci_sim_init_bus: pciDevice 0xffffffff80871230
KERN: ahci: AHCIController::Init 0:31:2 vendor 8086, device 1e03
KERN: ahci: PCI SATA capability found at offset 0xa8
KERN: ahci: satacr0 = 0x0010b012, satacr1 = 0x00000048
KERN: ahci: pcicmd old 0x0007
KERN: ahci: pcicmd new 0x0006
KERN: allocate_io_interrupt_vectors: allocated 1 vectors starting from 25
KERN: msi_allocate_vectors: allocated 1 vectors starting from 25
KERN: msi enabled: 0x0001
KERN: ahci: using MSI vector 25
KERN: ahci: registers at 0xd2538000, size 0x800
KERN: ahci: mapping physical address 0xd2538000 with 2048 bytes for AHCI HBA regs
KERN: ahci: physical = 0xd2538000, virtual = 0xffffffff8207b000, offset = 0, phyadr = 0xd2538000, mapadr = 0xffffffff8207b000, size = 4096, area = 0x00000434
KERN: ahci: cap: Interface Speed Support: generation 3
KERN: ahci: cap: Number of Command Slots: 32 (raw 0x1f)
KERN: ahci: cap: Number of Ports: 6 (raw 0x5)
KERN: ahci: cap: Supports Port Multiplier: no
KERN: ahci: cap: Supports External SATA: yes
KERN: ahci: cap: Enclosure Management Supported: yes
KERN: ahci: cap: FIS-based Switching Control: no
KERN: ahci: cap: Supports Command List Override: yes
KERN: ahci: cap: Supports Staggered Spin-up: yes
KERN: ahci: cap: Supports Mechanical Presence Switch: yes
KERN: ahci: cap: Supports 64-bit Addressing: yes
KERN: ahci: cap: Supports Native Command Queuing: yes
KERN: ahci: cap: Supports SNotification Register: no
KERN: ahci: cap: Supports AHCI mode only: no
KERN: ahci: cap2: DevSleep Entrance from Slumber Only: no
KERN: ahci: cap2: Supports Aggressive Device Sleep Management: no
KERN: ahci: cap2: Supports Device Sleep: no
KERN: ahci: cap2: Automatic Partial to Slumber Transitions: yes
KERN: ahci: cap2: NVMHCI Present: no
KERN: ahci: cap2: BIOS/OS Handoff: no
KERN: ahci: ghc: AHCI Enable: yes
KERN: ahci: Ports Implemented Mask: 0x000013 Number of Available Ports: 3
KERN: ahci: AHCI Version 0001.03.00 Interrupt 25
KERN: ahci: allocating 4096 bytes for AHCI port 0
KERN: ahci: area = 1077, size = 4096, virt = 0xffffffff8207c000, phy = 0x10b4f000
KERN: ahci: allocating 4096 bytes for AHCI port 1
KERN: ahci: area = 1078, size = 4096, virt = 0xffffffff8207d000, phy = 0x10b4e000
KERN: ahci: allocating 4096 bytes for AHCI port 4
KERN: ahci: area = 1079, size = 4096, virt = 0xffffffff8207e000, phy = 0x10b4d000
KERN: ahci: PortReset: port 0 undergoing COMRESET
KERN: ahci: Probe: port 0 link speed 6.0Gb/s
KERN: ahci: Probe: port 1 link speed 1.5Gb/s
KERN: ahci: PortReset: port 4 undergoing COMRESET
KERN: ahci: cookie = 0xffffffff8326e780
KERN: ahci: ahci_path_inquiry, cookie 0xffffffff8326e780
KERN: ahci: ahci_scan_bus, cookie 0xffffffff8326e780
KERN: ahci: sg_memcpy phyAddr 0xf9920c0, size 96
KERN: ahci: ahci_get_restrictions, cookie 0xffffffff8326e780
KERN: publish device: node 0xffffffff808e0f10, path disk/scsi/0/0/0/raw, module drivers/disk/scsi/scsi_disk/device_v1
KERN: publish device: node 0xffffffff808e0a10, path disk/scsi/0/1/0/raw, module drivers/disk/scsi/scsi_cd/device_v1
KERN: ahci: sg_memcpy phyAddr 0xf992070, size 32
KERN: vpd_page_get:
KERN: vpd_page_inquiry:
KERN: ahci: sg_memcpy phyAddr 0xf991f80, size 7
KERN: ahci: sg_memcpy phyAddr 0xf992120, size 8
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992120, size 64
KERN: periph_check_capacity: TRIM: Setting trim support to UNMAP
KERN: DMAResource@0xffffffff808e0e70: low/high 0/100000000, max segment count 32, align 2, boundary 65536, max transfer 130560, max segment size 3355KERN: 4432
KERN: ahci: sg_memcpy phyAddr 0xf992360, size 32
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992270, size 7
KERN: ahci: sg_memcpy phyAddr 0xf992410, size 8
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992410, size 64
KERN: ahci: ahci_ioctl, cookie 0xffffffff8326e780
KERN: ahci: sata_request::finish ATA command 0xa0 failed: status 0x51, error 0x24
KERN: ahci: sata_request::finish ATAPI packet 25 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 (len 10)
KERN: periph_check_capacity: TRIM: Setting trim support to disabled
KERN: intel: pm_identify_partition(0, 0: 0, 180045766656, 512)
KERN: btrfs: [7142376:    18] invalid superblock!
KERN: e[34mexfat:e[0m invalid superblock!
KERN: e[34mext2:e[0m invalid superblock!
KERN: identify(0, 0xffffffff80879428)
KERN: ntfs: error: identify_partition: boot signature doesn't match
KERN: raw_command:
KERN: ahci: AHCIPort::ScsiExecuteRequest port 0 unsupported request opcode 0x43
KERN: dos_std_ops()
KERN: intel: pm_scan_partition(0, 0: 0, 180045766656, 512)
KERN: intel: ep_identify_partition(0, 32768, 45256540160, 512)
KERN: intel: pm_identify_partition(0, 2: 32768, 45256540160, 512)
KERN: btrfs: [7143979:    18] invalid superblock!
KERN: identify(0, 0xffffffff808793c8)
KERN: raw_command:
KERN: dos_std_ops()
KERN: intel: ep_identify_partition(0, 87199612928, 92845113344, 512)
KERN: intel: pm_identify_partition(0, 3: 87199612928, 92845113344, 512)
KERN: btrfs: [7145665:    18] invalid superblock!
KERN: raw_command:
KERN: dos_std_ops()
KERN: Identified boot partition by partition offset.
KERN: ahci: sg_memcpy phyAddr 0xf992480, size 32
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992390, size 7
KERN: ahci: sg_memcpy phyAddr 0xf992530, size 8
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992530, size 64
KERN: ahci: sg_memcpy phyAddr 0xf992400, size 32
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf992310, size 7
KERN: ahci: sg_memcpy phyAddr 0xf9924b0, size 8
KERN: vpd_page_get:
KERN: ahci: sg_memcpy phyAddr 0xf9924b0, size 64
KERN: bfs: mounted "Haiku-R1b4" (root node at 524288, device = /dev/disk/scsi/0/0/0/0)
KERN: Mounted boot partition: /dev/disk/scsi/0/0/0/0
KERN: unknown: [7220936:    18] Adding packages from "/boot/system/packages"
KERN: slab memory manager: created area 0xffffffff95001000 (1126)
KERN: slab memory manager: created area 0xffffffff95801000 (1128)
KERN: slab memory manager: created area 0xffffffff96001000 (1129)
KERN: slab memory manager: created area 0xffffffff96801000 (1131)
KERN: slab memory manager: created area 0xffffffff97001000 (1132)
KERN: slab memory manager: created area 0xffffffff97801000 (1133)
Oh nice, where to get this dual monitor panel-holder?
Is it for Dell only?
Thanks
First of all before someone orders the same system: this works only because this computer has a good VESA BIOS, that will add the resolution from the display to the list of supported resolutions. If your VESA BIOS doesn’t do this, it will not work for you, and you will only have an ugly stretched display, at best.
In the posted syslog I think only the VESA driver was used. I see no logs from another driver.
So, maybe I was not clear enough or maybe I missed something. When you are on a black screen, you have to press the power button once (do not hold it) and wait for a bit. If the system is not crashed, it will shutdown cleanly (even if you can’t see anything) and write the logs to disk (so we can get them at next boot). Then, make sure to recover all files after restarting (syslog.old or previous_syslog if they are there).
If pressing the power button off does not work, likely the system is crashed and the logs won’t be saved. In that case, the only way currently to get the info out of the machine would be with an RS232 serial port, either one that’s on the motherboard or using expresscard (USB adapters won’t work). If you also don’t have that, it becomes a bit more complicated, but still some things can be tried. For example, typing “reboot” should reboot the machine, and after that, maybe the bootloader menu will have an option to save the previous boot log to a FAT32 formatted USB drive (it depends if your BIOS fully clears the RAM on reboot or not).
If that also fails, I am out of solutions for now, some code will have to be written to investigate this.
No that is a generic vesa mount holder from amazon, i think.
I am so happy that i have managed dual monitor support and all you are interested in is the panel holder :frowning:
<Sarcasm off> :wink:
I will investigate, System did not shutdown after short powerbutton press so probably crashed.
BTW it is a Thinkpad T430s, will try it on my other Thinkpads as time permits.
I do not have a express serial card
Hi ubu. Great to see dual screen Haiku.
I am very curious as to the box in the bottom left corner. An embedded Ryzen system :slight_smile: Looks very familiar.
That is a future Firewall :wink:
In any case, I tested a DualHead adapter from Matrox before 2018.
https://discuss.haiku-os.org/uploads/default/original/2X/2/20208d25ab62ed1f5e3c78c13a55339791a4c316.jpeg
I know that some old matrox and ati support multihead, but try putting them in a notebook :wink:
ADAPTER = extern…
EDIT:
Tested on an old HP Pavilion desktop and on an old notebook (fully compatible with Zeta, I used it for most of my daily work) that hasn’t been alive for a long time!
bing: halter fĂźr 2 monitore
I for one would like to know what splitter you used!?
