Is it possible to use tkinter?
Hi! Welcome!
Sadly, tkinter dead-locks when you try to use it, see: https://github.com/haikuports/haikuports/issues/6967.
Somewhere between Python → tkinter → tk / tcl → SDL (our libtk
port relies on SDL, see https://www.androwish.org) things go wrong, and no one has figured it out just yet.
Unfortunately no. Tcl/Tk on Haiku is based on UndroidWish, which doesn’t get along with whatever wizardry Tkinter does in the background and… yeah, see above. But Tcl/Tk itself works fine, if that helps. It’s just ugly. Edit: also, nowadays there are other bindings available such as PyQT5.
An interesting alternatives:
interesting, I’ll take a look
On that vein, there’s also Remi, and PySimpleGUI. Albeit I haven’t tried them yet on Haiku.
It would be possible if Xlibe supported Tk, which unfortunately it doesn’t. I was just looking into this again yesterday, and it seems the problem might be a missing API in Haiku itself. There might be a way to work around this inside Tk, but I didn’t dig into that just yet.
So, what is the best way now learn programming “python with Haiku”?
Try all this GUIs? To find out it does not work out?
Would be nice a professional python-programmer would look into this and recommend a successful way to use learn python with Haiku.
Self-promotion here, but why not try Haiku-PyAPI?
If there are widgets you need bound, you can always ask me.
