Hello all⦠is it possible to set the font path to home/config/non-packaged/data/fonts?
So I can install/deinstall the fonts I like?!
Because data/fonts is in the not writeable system folder!
Non-packaged are before system/packages. So if you add a font to non-packaged and the same are at system/packaged (there the package install it), the non-packaged are used
This has been fixed for a while, but the build has broken undetected and therefore the fixed version never made it into HaikuDepot.
Korli has fixed that, and now thereās a fixed 2.1.2-9 version of WonderBrush for 32bit at HaikuDepot. A 64bit version isnāt available at this time.
