Hi @michel , I am getting the same messages you posted on Mar 16, and immediately I did the ā Reconfigure, but I still get those messages. I have checked the files exist (I downloaded the parts of TexLive needed, but not the everything). The files LyX says it canāt access them, are all there.
Could you confirm you are still successfully running LyX with the latest updates from HaikuDepot please. That will answer my āCan actually be done with the current downloads?ā. I need to know it is actually possible and the problem is my end (probably my ageing head).
Please could you possibly also include your Paths settings in LyX Toolsā>Preferencesā>Paths
Everything seems to be working in TexMaker (downloaded to check files were there and accessible) except I am getting a āCould not start the command: pdflatex -synctex=1 -interaction=nonstopmode %.texā when I try to build the PDF. That is the Perl code against Latexmk in Configure Texmaker. I can run Latexmk in Terminal and Perl is installed! I want LyX anyway, so left it there.
Any other tricks you did to do to get LyX to run would be invaluable information. A lot of suggestions online are out of date (much earlier HD ports) and much is beyond my hacker level, given I have only been on Haiku 5 days.
My problems definitely appears to be LyX is not negotiating BeFS. It could not find the thesaurus, so I downloaded it from GitHub and placed it in a directory and directly pointed the Preferences path to the folder, did the ā Reconfigure, restart LyX :No luck . Do it again ⦠again ⦠After two days I am about to give up. The mythes from HaikuDepot ended in /boot/system/packages and there also is a .so version in /boot/system/lib! Basically I put a copy everywhere I know LyX might access.
I have uninstalled and reinstalled LyX a couple of time to see if it does a path detection as part of the install, initial run. No luck :-(.
It is a shame TexLive does not have the MikTeX ability to download any extra .sty and .cls files on the fly to keep install size and bandwidth lower, but that is not relevant here, except if I have to download 4GB I might not proceed as I am on mobile phone hotspot and my target box is running on 64GB partition of the Windows SSD of an little Intel N100 NUCs. Pretty good how well Haiku runs on it.
Latex however is amazing and I think it fits with the Haiku way of viewing the world (and beautifully formatting Haikus), so if I get a helpful leg up I will not give up.
Oh! If LyX is not 100% functional on your install, could you note what isnāt working for you please. I could not even access the Dictionary setting field, so I wonder if that somehow did not port to the Haiku version.
