Terminology / EFL fork to Haiku
Hi
This is a prelease of Terminology for Haiku
Notable features
  • tycat audio/video files with sound.
  • Lots of fonts, colors and other features to chose from.
Known Bugs
  • Currently crashes the system if using nebula driver!
  • Probably many more bugs but only minimally tested in a VM
Download
Updates with Fixes
  • Now uses Haiku Native Window and audio engine. No SDL
  • Works with nvidia “nebula” driver.
  • Disabled translucency and changing the rendering engine in elementary_config.
  • Loads super fast.
Well… my EFL experimenting can continue. This is a big supprise, even tho EFL is unknown to many, it proves itself to be a very mature framework. I love to use it on Enlightenmen and I will love it on haiku too. @ablyss Thank YOU !!!
@theokeist awesome blossom! The backend ELF tests are amazing, all sorts of cool toys to mockup a cool GUI. There some bugs and wrinkles I still need to work out with Claude, proper URL handling and some mouse freeze ups with Terminology. But so far I’m really pleased too :slight_smile:
Updates with Fixes
  • Fixed URL handling.. links, emails etc.. will open default application in Haiku.
  • Fixed a bug in that would case terminology to freeze up.
Updates and Fixes
  • Fixed copy and pasting from keyboard.
  • Added --gl flag for users who use mesa/llvm and want to run EFL apps in SDL Open GL window.
  • Mesa/llvm user settings are remembered so if you set the render to use GL in elementary_config it will remember it. ( Not an option for nebula users - see below ).
  • Added --nebula flag for users who want to test the sdl opengl window but be advised doing so will freeze the entire system when the window is closed. Maybe a driver issue. This is the only way to test nebula. Adjusting the render is disabled in elementary_config if you use nebula.
Updates
  • Added drag and drop folders and media.
Preview Video
