Hi all
when i forget some command that i have been input before… in linux usually i check with
cat ~/.bash_history |grep mycommand
how to do similiar thing on haiku terminal?
Hi all
The portable way to do this would be history|grep mycommand
, or just control+R mycommand
You can use my little Tool bash_history switche for storing and restoring you used commands too.
To found on our repo server, : http://software.besly.de
Documentation: http://old.besly.de/menu/search/archiv/sys/bash_history-switcher_eng.html
You can do a Ctrl-R like PulkoMandy suggested or, if you want access to the history file, the file is “/boot/home/config/settings/bash_history”. At least that’s where the file is on my Haiku installation.
thanks @PulkoMandy @lelldorin and @claudiom for response
best regards
