Katisu wrote:
umccullough wrote:Next, from a commandline run sobservice -i in the SB directory (to install the service)That would be part of the problem. I found where I misunderstood the directions.
Got it going, we’ll see if my rate actually goes higher.
you can also manually run multiple clients, by setting up multiple cache keys in the registry and altering the config\ClientKey to each separate cache key before running sb.exe – that way when you run sb.exe manually each time, you can control which cache key it uses from the registry…(good if you want to manually start a copy to finish a k/n combo that didn’t finish before) each instance remembers which cache key it’s using until it terminates.
