I’ve got a Macbook Pro 8,2 which I’ve tried Haiku on. It’s… super unhappy.
For every boot, one of four things happens:
- it boots relatively normally.
- it takes a really long time to boot (usually waiting for ~20s at the Card icon on the boot screen), and then continues. I get a semi-working system with some USB devices non-functional. The MBP has the keyboard and touchpad connected via USB internally, so occasionally this makes the machine simply noninteractive. Enabling debug tracing shows lots of errors during USB initialisation.
- it crashes into KDL on boot. (With the keyboard unresponsive, sadly.)
I got a picture! The debugging log shows a bunch of ‘host failed to reset’ / ‘bus failed init check’ errors, plus the KDL stack trace.
These Macbooks are pretty cursed, but I don’t think this is a hardware fault — it runs OSX fine. A null point dereference caused by a USB object failing to deconstruct properly after getting confused by Apple’s weird hardware, perhaps?
