A small update to the BFS incompatibility: I’ve now ported the original logging structure to the R5 version of BFS as well, so that the tools like bfs_shell can now successfully mount “dirty” volumes, too. I also found another bug in Be’s implementation, and needed to cut down the log entry array by one to make it work with larger transactions.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/axeld/2005-10-19_sub_transactions/
