I m trying to connect to a server with byobu enable by default.
In order not to lauch byobu at ssh connexion the LC_BYOBU variable should be set to 0
But
LC_BYOBU=0 ssh server
does not seems to work from haiku terminal and the haiku OpenSSH client.
I can manage to do it from putty.
How can I make the haiku ssh client to correctly send env variable ?
Additionally, ssh reads ~/.ssh/environment, and adds lines of
the format ``VARNAME=value’’ to the environment if the file
exists and users are allowed to change their environment. For
more information, see the PermitUserEnvironment option in
sshd_config(5).
I don’t have my haiku laptop with me so i can not test but apparently linux default configuration is to have LANG and all LC_* variables sent without explicit action from the user ( i mean without the need of `ssh -o "SendEnv LC_BYOBUˋ)
Which is apparently not the case for haiku default configuration.
May be adding ˋSendEnv LANG LC_*ˋ to the default haiku ssh client conf (ssh/ssh_config ) as most linux distributions could be a good thing no ?
it is the case at least for debian and ubuntu (and macos)
Achtung ! i’m not talking about the server side which may or may not accept the env variables (or filter them) which is apparently what you are talking about on the previous post.
i’m talking about the client side ! the client should send by default LANG and all LC_* variables .
