I noticed that when opening SoundRecorder I get the error “Could not find default audio hardware: Name not found” with a “Stop” button as the only action to close out.
The error is expected for me, but was curious if ‘Stop’ should be changed to ‘Quit’. It would seem to better align with other applications, but wanted to ask here first.
‘Stop’ would be to close the process, if that’s the case it makes sense, ‘Quit’ to close the window, without stopping the process, would be correct, you would have to know what action to take when clicking the button.
I would think ‘Quit’ works best. Its a bit weird though since in my case the actual application never opens (or is visible, presumably because I run within a VM).
