It does work in Windows XP, yeah. The drivers provided for it on that website work out of the box. Its just Haiku that doesnt like it.
The onboard or the add-in?
The add-in Iād write off. Haiku hasnāt got a driver and neither does Opensound it seems.
If the onboard is working there, can you find the device IDs from Device Manager? This is on 10, but this is similar back to 2000
In this case, the sound card is 0x10ec 0x0287 which is a Realtek HDA card (possibly the same one as that board as, even though this is a 2022 laptop).
Iāll have to get back to you on that- Iād need to reinstall Windows to it. I can do that on a different harddrive but it takes a while.
From ArsockĀ“s site description
ā- 7.1 CH WindowsĀ® Vistaā¢ Premium Level HD Audio (ALC888 Audio Codec)ā . From the picture, cannot read the markings of the possible chips ( the long one, near the green front audio connector, and the small Realtek one, near the last ( bottom ) pci slot.
Do you mean the Soundblaster Live! doesnāt work in the latest Haiku release?
It is working great!
![](https://discuss.haiku-os.org/letter_avatar_proxy/v4/letter/c/97f17d/48.png)
Thatās a soundcard type Iāve never heard of and I donāt think weāve any driver family similar to it
Well, it appears to be somewhat compatible with the Sound Blaster 16 but over PCI instead of ISA.
There is documentation: https://www.dosdays.co.uk/media/avancelogic/ALS-Datasheets+Manuals/ALS4000A.PDF
And there is a driver from FreeBSD: Cross Reference: /freebsd-current/sys/dev/sound/pci/als4000.c
It makes me wonder if our compatibility layer for FreeBSD may be usable for soundcards as well as network cards?
