Sound card didn't work
Hi, i have USB sound card like a STLab M303 C-Media 6206, and i have no sound in system, volume control say me:
could not find the mixer
in media app i see this:
master output - not connected
system see soundcard like this
0d8c:0102 /dev/bus/usb/0/0/3 “C-Media Electronics, Inc.” “CM106 Like Sound Device” ver. 0010
There’s no support for USB sound yet.
I installed cheap USB sound card. It is recognized, but I don’t hear any sound. Is it only for me or all other people have this problem with USB Audio sound card?
Normal, integrated sound card works OK.
What chipset is it using?
Only a subset of USB sound cards are supported, those using Class 1 I believe.
Newer cards, particularly those with multiple inputs, are usually Class 2.
Bus 003 Device 002: ID 0d8c:000e C-Media Electronics, Inc. Audio Adapter (Planet UP-100, Genius G-Talk)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0d8c C-Media Electronics, Inc.
idProduct 0x000e Audio Adapter (Planet UP-100, Genius G-Talk)
bcdDevice 1.00
iManufacturer 0
iProduct 1 Generic USB Audio Device
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 253
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 0
iInterface 0
AudioControl Interface Descriptor:
bLength 10
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 100
bInCollection 2
baInterfaceNr( 0) 1
baInterfaceNr( 1) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 2
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 1
wChannelConfig 0x0001
Left Front (L)
iChannelNames 0
iTerminal 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 6
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 9
iTerminal 0
bLength 9
bDescriptorType 36
bTerminalID 7
bAssocTerminal 0
bSourceID 8
iTerminal 0
bLength 7
bDescriptorType 36
bDescriptorSubtype 5 (SELECTOR_UNIT)
bUnitID 8
bNrInPins 1
baSource( 0) 10
iSelector 0
bLength 10
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 9
bSourceID 15
bControlSize 1
bmaControls( 0) 0x01
Mute Control
bmaControls( 1) 0x02
Volume Control
bmaControls( 2) 0x02
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bUnitID 10
bSourceID 2
bControlSize 1
bmaControls( 0) 0x43
Mute Control
Volume Control
Automatic Gain Control
bmaControls( 1) 0x00
iFeature 0
bLength 9
bDescriptorType 36
bUnitID 13
bSourceID 2
bControlSize 1
bmaControls( 0) 0x03
Mute Control
Volume Control
iFeature 0
bLength 13
bDescriptorType 36
bDescriptorSubtype 4 (MIXER_UNIT)
bUnitID 15
bNrInPins 2
baSourceID( 0) 1
baSourceID( 1) 13
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
bmControls 0x00
iMixer 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 2 Discrete
tSamFreq[ 0] 48000
tSamFreq[ 1] 44100
Endpoint Descriptor:
bLength 9
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 9
Transfer Type Isochronous
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 1 Milliseconds
wLockDelay 1 Milliseconds
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 7
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 1
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 48000
tSamFreq[ 1] 44100
bLength 9
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0064 1x 100 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 0 Undefined
wLockDelay 0 Undefined
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 50
Report Descriptor: (length is 50)
Item(Global): Usage Page, data= [ 0x0c ] 12
Consumer
Item(Local ): Usage, data= [ 0x01 ] 1
Consumer Control
Item(Main ): Collection, data= [ 0x01 ] 1
Application
Item(Global): Logical Minimum, data= [ 0x00 ] 0
Item(Global): Logical Maximum, data= [ 0x01 ] 1
Item(Local ): Usage, data= [ 0xe9 ] 233
Volume Increment
Item(Local ): Usage, data= [ 0xea ] 234
Volume Decrement
Item(Global): Report Size, data= [ 0x01 ] 1
Item(Global): Report Count, data= [ 0x02 ] 2
Item(Main ): Input, data= [ 0x02 ] 2
Data Variable Absolute No_Wrap Linear
Preferred_State No_Null_Position Non_Volatile Bitfield
Item(Local ): Usage, data= [ 0xe2 ] 226
Mute
Item(Local ): Usage, data= [ 0x00 ] 0
Unassigned
Item(Main ): Input, data= [ 0x06 ] 6
Data Variable Relative No_Wrap Linear
Unassigned
Item(Global): Report Count, data= [ 0x04 ] 4
Item(Global): Logical Maximum, data= [ 0xff 0x00 ] 255
Unassigned
Item(Global): Report Size, data= [ 0x08 ] 8
Item(Global): Report Count, data= [ 0x03 ] 3
Unassigned
Item(Main ): Output, data= [ 0x02 ] 2
Item(Main ): End Collection, data=none
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 32
Device Status: 0x0000
(Bus Powered)
