VAIO VGN-SR19XN - Haiku
SPECS:
- Intel Core 2 Duo P8400 @ 2,26 GHz
- Ram 3 GB DDR2 800 MHz
- 13’3 inch 1280x800 display
- GPU Intel GMA 4500M HD
- HDD 160 GB 5400 rpm TOSHIBA MK1652GSX
- DVD RW Optiart AD-7910S
- Ethernet 10/100
- Wifi 802.11n
- Bluetooth 2.0 + EDR
- 2 USB 2.0
- Card Reader SD/MS
- VGA out
- Firewire port
- Built in camera 1.3 Mpixel
STATS:
~> uname -a
Haiku shredder 1 hrev52130 Jul 17 2018 23:48:28 x86_64 x86_64 Haiku
li~> listdev
device Serial bus controller (SMBus) [c|5|0]
device 2930: 82801I (ICH9 Family) SMBus Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 2929: 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode]
device 2919: ICH9M LPC Interface Controller
device Generic system peripheral [8|80|0]
vendor 1180: Ricoh Co Ltd
device 0592: R5C592 Memory Stick Bus Host Adapter
device Generic system peripheral (SD Host controller) [8|5|0]
device 0822: R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter
device Serial bus controller (FireWire (IEEE 1394), OHCI) [c|0|10]
device 0832: R5C832 IEEE 1394 Controller
device Bridge (PCI bridge, Subtractive decode) [6|4|1]
device 2448: 82801 Mobile PCI Bridge
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 293a: 82801I (ICH9 Family) USB2 EHCI Controller #1
device Serial bus controller (USB controller, UHCI) [c|3|0]
device 2939: 82801I (ICH9 Family) USB UHCI Controller #6
device 2936: 82801I (ICH9 Family) USB UHCI Controller #3
device 2935: 82801I (ICH9 Family) USB UHCI Controller #2
device 2934: 82801I (ICH9 Family) USB UHCI Controller #1
device 2946: 82801I (ICH9 Family) PCI Express Port 4
device 4232: WiFi Link 5100
device 2944: 82801I (ICH9 Family) PCI Express Port 3
device 2942: 82801I (ICH9 Family) PCI Express Port 2
vendor 11ab: Marvell Technology Group Ltd.
device 4354: 88E8040 PCI-E Fast Ethernet Controller
device 2940: 82801I (ICH9 Family) PCI Express Port 1
device 293e: 82801I (ICH9 Family) HD Audio Controller
device 293c: 82801I (ICH9 Family) USB2 EHCI Controller #2
device 2938: 82801I (ICH9 Family) USB UHCI Controller #5
device 2937: 82801I (ICH9 Family) USB UHCI Controller #4
device Display controller [3|80|0]
device 2a43: Mobile 4 Series Chipset Integrated Graphics Controller
device 2a42: Mobile 4 Series Chipset Integrated Graphics Controller
device Bridge (Host bridge) [6|0|0]
device 2a40: Mobile 4 Series Chipset Memory Controller Hub
WORKING
- Wifi
- Intel Video Driver (Rendering issues on screen, usually with scrollbars, or moving windows with graphic content)
- Wacom Graphire A6 classic USB
- Microsoft touch wireless mouse (takes time to recognize it when plugging the receiver)
- PrintScreen, it does capture the screen to be saved
- USB drive access. Mounts the pendrive read only or read-write
- Pinyin Chinese works though has to be typed character by character
HALF WORKING
- Bluetooth BCM92046 Links to phone but takes ages to pair, but that is about it, no file transfer, not anything, just pair (also causes wifi connection drops)
- Arrow Keys don’t work properly (maybe because the computer is old, but works fine in BIOS and bootmanager)
Arrow keys don’t work properly even in the BIOS. Sorry, my mistake… - Connect phone through USB to transfer photos with PhotoGrabber makes PhotoGrabber go crazy, scrolling the same photo again and again and again and again, and when switching workspaces the PhotoGrabber location on the screen turns grey on other workspaces
NOT WORKING
- Power Manager (computer is extremely hot all the time. Battery level does not work properly and computer turns off on battery after 5 minutes, wether batery level is still at 76%)
- Close lid doesn’t suspend
- TCP/IP printing
- Fn keys for volume up/down, brightness…
- VGA Out … plug the VGA cable with laptop on locks the system. Restart with the VGA cable plugged starts the syste with laptop display on but messed up (contetns fill left half of screen, right half appears black with some wobbling vertical lines), and external display “Out of Range”
- Plug a phone through USB doesn’t result in anything. Phone storage does not mount (Android phone)
- SD Card Reader does not recognize SD card
- Motion Eye Webcam not recognized by the OS
- Shutdown does not work either. Restart does
- Samba Shares don’t show anything on the network
I will keep this machine with Haiku. Hope the Video out can be fixed soon, so I can use it for the meeting presentations.
Regards,
RR
