Some QT, KDE software interface using Chinese is a box, how to solve?For example,Notepadqq,QMMP
Some QT, KDE software interface using Chinese is a box, how to solve?For example,Notepadqq,QMMP.
I know it’s a font problem,but haiku is installed by default “Noto Sans CJK JP” Font, also, the QT-based software cannot choose the system default installed “Noto Sans CJK JP” Font.
Finally, after I installed the “Wenquanyi Micro Hei” font via repo, QT based software can select “Wenquanyi Micro Hei” font in the font selection interface and successfully display Chinese.
why?
I think this is related https://github.com/threedeyes/qthaikuplugins/issues/3
not yet merged repo?
It should be added as a patch to haikuports recipe since qthaikuplugins HEAD contains a bug which prevents clipboard from working.
Update qthaikuplugins package to the latest version and try again.
After update qthaikuplugins packag, it’s has been solved. thinks.
You’re transplanted QT、KDE software developers?
I found software have the following question : based on QT、KDE.
1、Maximization is based on KDE、QT of software, Haiku Deskbar will be covered by the software,But the original Haiku software doesn’t cover.
2、In haiku-X64 use Smplayer playing the video, it appeared a few windows, how to solve this?
3、Some KDE, QT based software, no language settings options, usually automatically acquire system language settings for the software itself language settings,For example:Calligra Suite not the language settings options,However, I have set haiku to Chinese, these software can not get my language settings, and can not automatically become the Chinese interface.How can I make these software into Chinese interface?
These are all known issues. Anyway, please file all of them at https://github.com/threedeyes/qthaikuplugins/issues hopefully someone will look into them eventually.
BTW, it’s Qt, not QT (QuickTime) :slight_smile:
Yes. Thanks for your work.
