Hi All,
I would love to have this app working, but I get the following error:
I am using r1beta6/current
Hi All,
Since you are running H1B6, you should open a ticket at HaikuPorts (if you have not done so).
I am still on H1B5 (stable)…not nightly versions. I am waiting for the H1B6 release before I start upgrading and testing everything.
BTW…never seen that issue before and I use RawTherapy on Haiku.
Good luck!
regression 3.0.3: jpeg_std_message_table unexported, breaking rawtherapee run-time and compilation · Issue #767 · libjpeg-turbo/libjpeg-turbo · GitHub? libjpeg_turbo removed that symbol and we have the new version without it since May. It seems we’d need to either add the patch to RawTherapee or just update it to 5.11 or later.
Did a quick check with 5.13, text doesn’t show, so that’s a nogo (for me at least) for now.
5.11 straight crashes on launch (nothing in Terminal), from syslog:
KERN: debug_server: Thread 12525 entered the debugger: Segment violation
KERN: stack trace, current PC 0x676dcc306f </boot/system/lib/libglibmm-2.4.so.1.3.0> _ZN4Glib7ustringC2ERKS0_ + 0xf:
KERN: (0x7f5718ef04d0) 0x157fd3a9c31 </boot/system/apps/RawTherapee> _ZN8rtengine10procparams21ColorManagementParamsC2Ev + 0x101
KERN: (0x7f5718ef0500) 0x157fca3c4c8 </boot/system/apps/RawTherapee> _GLOBAL__sub_I_histogrampanel.cc + 0x18
KERN: (0x7f5718ef0520) 0x2aa824340f </boot/system/runtime_loader> _ZL17init_dependenciesP7image_tb.constprop.0 + 0x19f
KERN: (0x7f5718ef05d0) 0x2aa8243d9c </boot/system/runtime_loader> load_program + 0x1dc
KERN: (0x7f5718ef0660) 0x2aa824b4a3 </boot/system/runtime_loader> runtime_loader + 0xf3
KERN: debug_server: Killing team 12525 (/boot/system/apps/RawTherapee)
KERN: debug_server: TeamDebugHandler::Init(): Failed to get info for team 12525: Operation on invalid team
KERN: debug_server: KillTeam(): Error getting info for team 12525: Operation on invalid team
KERN: debug_server: Killing team 12525 ()
Use the previous older library. You can get from HaikuDepot.
Use R1B5 for stable OS.
Place request ticket with HaikuPorts for newer 5.12 version - if needed or further issues/needs/wants.
Wow, awesome guys will try it out ..
EDIT: Works great, thanks again
Raw therapy unfortunately crashes soon as you want to export a tiff file of any sort (8,16,32 bit) I have posted a bug on HaikuPorts, it is unusable at present ..
