A new install of nightly Haiku and the pkgman install of mercurial is no longer working for me. Ie hg clone …. The error in the stack trace is:
File "/boot/system/lib/python3.10/vendor-packages/mercurial/sslutil.py", line 105, in _hostsettings
assert supportedprotocols - {b'tls1.0'}
I then try running from source…
So I installed python 3.14 using pkgman:
> python -V
Python 3.14.0
However it doesn’t have ssl?
> python ./get-pip.py
WARNING: Disabling truststore since ssl support is missing
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Weird… cause I have openssl 1.1.1 and 3 installed…
AFAIK, openssl 1.x should not be in use for any (up-to-date/rebuilt) package (that version got EOL’ed in 2023).
I’d try first uninstalling openssl 1.1.1, and see if that helps (take notes of any package that gets uninstalled along with that old openssl, if any, we should try rebuilding it against openssl 3.x).
