Hi all, i try to use “Mail”. But my first message went wrong. Now it is stuck in the maildeamon.
How do i get the maildeamon flushed?
Thx, Nico
Thx, Nico
Welcome Pitmeester!
Not quite sure what “stuck in mail_daemon” is. You can use “Find…” from the Deskbar and query for E-mails with status = “Pending”. You can then delete the found email, or change its status with the Tracker add-on “Mark as…”.
That done, the mail_daemon won’t try to send it anymore. If that was the problem…
I hesitate to speak for Pitmeester, but it’s not unlikely that he would like to know how to get emails to get sent. The documentation I’m looking at doesn’t mention a log file, but there probably is one?
No Humdinger you were right. This was the solution.
Thank you very much, Nico
