(solved)Iceweasel: Does not open after installation
Installed just now. Unable to launch it…does not open…
Do you have libevent and pciutils installed ?
I think dependency are not very well designed in the new iceweasel package…
@Bebert thank you for reporting problem and supporting other user.
I updated package to 128.0.5-3 that should fix dependency problem.
So far I haven’t seen pciutils passing by, could you explain how it fits into the picture?
Just did a clean install on a rather clean 64bit install, works fine so far.
Haikudepot is having some issues…will try later andreport back
Thanks…haikudepot is having some issues at the moment…not showing the packages…will try later and report back
A few months ago, pciutils was used by Nightly to run glxtest during the launch… so I thought it was necessary, may be I am wrong.
Todays update installed libevents and Iceweasel was also upgraded.
Iceweasel opens now
Thanks to all …
