after see some package update and see wxQt package… i want to test audacity port…
to enable build i’m remove question mark before x86_64 …
(system: haiku64bit hrev52688 on virtualbox on windows1064bit)
after that i execute
haikuporter audacity
… after downloading source… it throw exception
general system error… /boot/home/haikuports/media-sound/audacity/work-2.1.2/source/audacity-minsrc-2.1.2/lib/src/twolame/doc
i check the folders and that folder doesn’t exist…
i think the package is corrupt… so i download the source tracked from recipe… and download from chrome on windows 10 and try to extract it…
the weird is the source is ok… no corrupted one …
i try to compress it to various format (zip, 7z, tar)… then copy into vm …
and try to extract it…(with various extrator.unzip 7za …untar ) but always failed with
unfinished extract … folder missing… etc…
I wanted to do the same thing but it seems impossible for now:
There is no support for wxQt, wxX11 or other wx variants, as they are incomplete in key areas. The GTK+ headers are also required as Audacity includes extensions to wxGTK which need the underlying toolkit headers to compile.
@Diver…
i try another application …notepadqq (available on depot… jut curiously testing haikuporter)
haikuporter notepadqq
after downloading source… it seem failed to extract it
unpacking source of v.1.4.0.tar.gz
[error -1] general system error : ‘/boot/home/haikuports/app-editors/notepadqq/work-1.4.0/sources/notepadqq-1.4.0/doc’
so… i think thereis problem on decompressing process… because checksum is ok
problem and solution found…
after fscheck-ing … it found filesystem error and fortunately can be fix…
after that i retry haikuporter … it pass extracting activities… and start to build…
Technically you can have GTK compiled (i provided GTK3 recipe), but as there is no windowed backend in Haiku yet, you would have to run the gui part on a browser (with the Broadway backend).
Not really a good option for now, despite it working at native speed and so.
