Is there any way to have haikuporter tool install automatically the dependancy packages for a specific port ?
So far I have to install manually with pkgman the dev packages (where the names are not always straightforward), so I’m wondering if it’s the good approach.
Yes, i don’t know the flag by heart but you can check with the --help flag. There is an option to install all dependencies automatically.
Ah yes haikuporter --get-dependencies
Thank you !
If you cloned the tool there is a sample config file that contains a alias to haikuporter, this included the dependencies option.
