64 bit hrev56127
Can you add your locale/language settings to the ticket? I’m sure the separator issue is my fault as I added that support not too long ago. Not sure if the E32 is related to my change.
Yes, that is exactly the hrev where it broke. I know what the problem is and I’m fixing it.
I think it’s good now - just need to get it past the code review:
hrev56132 fixed
