Snaketracker-1.0.8
Hi all,
My latest toy to share with the community…
Snaketracker
It’s basically a retro BeOS/Dano Tracker and Deskbar that mimics the snaketrail feature found in the leaked source of BeOS.
It’s not a 100% clone of course, and lacks some of those serious widgets Dano had to offer, but none the less, it’s a snake trail!
It’s easy to install and uninstall.
Just install the hpkg and reboot.
Built against the latest Haiku nightly and will be updated if need be if Haiku upstream changes and something breaks.
Download 64bit
does this affect haiku “start menu” ?
Yes
Version 1.0.15 is out with a fix for the separation line/gap that Haiku adds automatically for each new sub-menu.
This fix is possible without having to edit deep Haiku source code by adding a 1pixel borderless tooltip window to cover up the separation gap. Overall result.. a more fluid and connected snaketrail.
thank you very much.. i like it
I dig it! Looks good with the xfce “b6” decorations enabled
Snaketracker 1.0.22 Released.
  • Added snaketrails starting on the top of the Deskbar.
  • Added bulge effects, flatlook to the snakes vertical and horizontal trails.
  • New scrollbar look added. See screenshots
Latest Updates
Love it! Especially with that theme. Great work!
Latest Snaketracker…
Lots of customization. :smiling_face_with_three_hearts:
hello, just a quick question
if it is availible in github then why you are posting under topic proprietary and other?
Because it’s AI assisted and the forum rules requires I post it this way regardless where I host the repo
this looks frickin’ gorgeous. it reminds me of amiga os (now AROS) and early iterations of englightenment wm for linux and of course winamp skins.
adding a drop of playfulness to the os will scratch that itch that us old desktop modders love! a true period homage!
Latest updates and newly added hpkg files to the repo.
  • Deskbar submenus fixs *some menus would still show the stock look
  • Tracker menus *matches the raised snake look
  • Rounded corners are off by default. You can toggle them on if you want,
    but adds a little ding to the cpu and you may still see the box window frames with certain wallpapers and Appearance color settings.
  • New Settings menu in Tracker settings with lots of new settings and tooltips to explore and have fun with…
It’s ok for the snake-like path effect, but new window decorations move the “close gadget” to the right. It’s a complete heresy against Haiku. I mean it. :slight_smile:
Happily it’s just an option.
:slight_smile: Took me a while to realize what you where taking about :stuck_out_tongue:
I agree with you! Maybe a future version “b6+” for us folks who like the close button widget were it was :wink:
The thing is, I have to mock up really, really really well anything I feed to the AI. So, it won’t be click and done :smiley:
Yes! Put me down as a +1 on this idea. I love the b6 theme but always want to click left and have to remember where the close icon is. Stacked/tabbed windows also look a little odd in b6 but i feel like that could be fixed as well at some point.
Working on it now… wish me luck :stuck_out_tongue:
@dakota New decorators are up.
You can download them in the latest package release found here
Two new b6 decorators
  • b6+
    screenshot13
  • b6+r
    screenshot15
Slight update to b6+ and b6+r, just reversed the hover over and hover close colors.
