Before I open a bug report for this, if it is a bug, I thought I’d check on here that I’m doing this the right way first.
I want to use mpv as my default video player under Haiku. Currently, when I click on a mp4 file it gets played with MediaPlayer.
What tried doing:
Right click .mp4 file → Add-ons → FileType
Now in the File type box I have video/mp4 which looks correct to me so next I click on Select in the Preferred application pane, I select the Haiku disk from the file selector drop down menu → System → bin → mpv then click on Open and I get the error:
Could not retrieve application signature
Is it not possible to use mpv as the default Tracker video player? I installed mpv from the HaikuDepot. mpv works fine when run from the terminal.
hrev56976 amd64
