Is it possible to set custom Tracker file attributes programmatically?
I’ve tried adding the following, but when my app opens a Tracker window the attributes are not visible unless I use FileTypes to add them and mark them as visible:
I may have misused the feature, but my experiments on the subject lead me to understand the contrary. Maybe I faced bugs of the Tracker, I had many strange behaviour when I was playing with it.
It’s only after crawling the people app that I deduced the need to create indexes on the FS so they would appear in the Tracker window
The attribute columns that you can add to a Tracker window are tied to the file file type identified. But it makes no sense to display all attributes in columns, some are only visible in attributes tab of Tracker file information window.
