Hi,
I try to set the output audio frequency to 41000 kHz but I can’t change it by the audio panel. (forced to 48000kHz.
Is there an other way to do this?(ex:in a config file) Cause I use a VM, and when I playing a music that’s lag a little bit.
I have already set Pulse Audio on Qemu on Debian by the way explain here:
Harmonize sample rates of host and guest system
The way is this:
Setting default sample rate in Linux
open /etc/libvirt/qemu.conf via
sudo nano /etc/libvirt/qemu.conf
and uncomment the line
user = "example"
(user = “root” for me)
replace your username with example
open /etc/pulse/daemon.conf
and find/add/uncomment the lines and set these values:
default-sample-rate = 44100
alternate-sample-rate = 48000
afterwards restart the pulse audio service via
pulseaudio -k
or reboot.
All this tutorial from the link above.
It seem work but lag sometimes again.
Thanks for reply.
