Does anyone have a script (reposetup.zip or equivalent) to generate your own repository?
There is a short guide, but the link to the script does not work.
http://besly.de/index.php/en/package-system/setting-up-a-software-repo (tutorial by bbjimmy, he is one of the first ower of a own repo)
http://besly.de/index.php/en/package-system/repomaker (lorglas generates a tool to create repo files)
http://besly.de/index.php/en/package-system/hpkg-creator (My hpkg tool to create hpkg files - in many parts diverent to the current build - need to rewrite it)
Thanks, I’ll take a look.
But I would like simple scripts (without GUI). Maybe that uses HaikuPorts.
I know how to create a package.
I need a script to create my own http repository. Like repomaker, but without gui (bash, python, perl …etc)
http://haiku.kacperkasper.pl/repo.zip
This is an updated script which will also generate a list of packages in .html files, but most of the guide still applies.
Thank you.
This is what I was looking for.
I did not know about command package_repo
in Haiku
